PDR HX 40
Old Nov 5, 2002 | 07:41 PM
1ST GEN.'s Avatar
PDR HX 40
HOW MUCH BOOST DOES A PDR HX 40 PUT OUT AND WILL I BLOW THE INTER COOLER OR ANY THING ELSE
Old Nov 6, 2002 | 06:23 PM
Michael  Az's Avatar
Re:PDR HX 40
The intercooler is pretty tough and I don't think you will hurt it. I would stay away from nitrous though.<br>Michael
Old Nov 8, 2002 | 06:59 AM
PourinDiesel's Avatar
Re:PDR HX 40
1st Gen.<br>Its not how much boost the HX40 puts out.<br>The advantage of this turbo is that it provides cooler air and can move exhaust out quicker then the stock HX35.<br><br>I could hit 39-40 PSI with my stock HX35 but my Autometer EGT gauge would be hitting the 6 o' clock position probably 1800 degrees or more!<br>With my PIERS super HX40 with the 16cm turbine housing and 14cm compressor housing, I can hit about 35-36 PSI but<br>I peg out on EGT's at about 1600 degress then recess to about 1400 on cruising at Wide open throttle.<br>In my opinion alot safer then 1800 degrees!! (meltdown temps!)<br><br>Peformance on these units is great, you can usually gain 50hp on a dyno run with a Piers 40 or even more if you use the bigger 18.5 cm housing, if you have the fuel there to burn.<br>IMO<br><br>--Justin
Txwelder
14
Nov 11, 2007 04:28 PM
Hawkeye
Sep 23, 2003 08:22 PM
Nicholas
Mar 14, 2003 04:14 PM
nascar mark
Nov 14, 2002 01:29 PM
Bushy
Nov 1, 2002 10:18 AM
