Twins???
oh yah a couple more questions, would a twin turbo kit for a 94-98 truck work on my 1990, since i know they don't make them for our 1st gens. also i was wondering if making my own exhaust manifold out of steel instead of cast iron would be a bad thing. i always notice the the exhaust manifolds are cast, even the ats manifolds are cast and nobody makes a steel one, why?
As Cody stated.. not sure the later model kits will fit because of the location of the frame and the AC/heat box??? (compared to the later trucks..) The turbos would work.. just might have to redo some of the piping..
If money becomes an issue.. spend your money on the inside stuff.. O-rings, cam, studs.. Then work your way into the twins and bigger injectors...
Bryan
Bryan
hey begel1 said that a stock intercooler can only handle up to about 60psi, is that true,(no offense begle1) also with a twin turbo setup, not a crazy one for drag racing, but a normal twin setup, will i be boosting 60-80 psi? and would it just be cheaper to not intercool the twin setup and put on a water meth system? thanks
If both turbos are wastegated, you can set the boost to be wherever you want it. 60 psi is not an unreasonable figure.
The manifolds are cast because they have to support the turbo.
[The manifolds are cast because they have to support the turbo.[/QUOTE]
not trying to sound dumb or anything but does that mean a steal exhaust manifold can't support the turbo?
not trying to sound dumb or anything but does that mean a steal exhaust manifold can't support the turbo?[/QUOTE]
A steel manifold would work but some bracing of the turbos would be required. W/o the bracing the manifold would most likely crack under the weight of one turbo, let alone 2. Cracking is always and issue with a forced induction/turbo motor. The expansion and contraction wreaks havoc on the metal. Cast iron is the way to go.
dodgediesel
17
Apr 5, 2011 11:21 AM
Stock 02
28
Sep 24, 2006 11:09 AM
stlsparky
Nov 21, 2005 10:02 PM
