Twins???
dangit dave. i was thinking that chemical intercooling could take the place of a CAC. i have lowered my compression with just a head gasket, and not always happy with the results. unless your building an all out race truck, i wouldn't recommend low compression, just o-rings and studs. much more fun to be around.
I hear ya on the compression. Not the best thing on a cold morning, but it helps keep the HG alive with a lot of boost.
Water/meth would help, but two compressors make an awful lot of heat. One turbo at 35 psi discharges at over 250 degrees. Add another one on top of that and you are going to see 500 - 600 degrees in the manifold. That's really going to hurt density.
hey just a few more questions and i'll stop picking your brains for more info. in the quest for MORE POWER
would it be better to put in lower compression pistons, huge cam like the f1 diesel cam, pods or edms, 3200 or 4000rpm gov spring with 60lb springs of course, fuel pin, and piston lift pump and possibly upgrade the compressor to a 60mm, or maybe the 56mm is okay? OR.... put on twins with the same pump mods and injectors, but no cam or lower comprssion pistons. i now this may sound dumb but i don't want to go into debt over this engine
i figure twins is the more expensive way to go, but i like to look at all my options.
ATS has pricing for o-ring or fire ring on their website. 1318.82cdn for fire ringing or 987.64 cdn for o-ringing the head. O-ring can handle 70psi fire ring will basically take more then your bottom end!
and you should be able to get o-ringed for $300.
hey begel1 said that a stock intercooler can only handle up to about 60psi, is that true,(no offense begle1) also with a twin turbo setup, not a crazy one for drag racing, but a normal twin setup, will i be boosting 60-80 psi? and would it just be cheaper to not intercool the twin setup and put on a water meth system? thanks
almost a thousand dollars to o-ring the head!!
I would have expected higher temps.
