Turns on the full power screw
Mine is about 3 turns or more,, mabey even 4, Make sure you have a piece of 2x4 ready, and the hose off the inake of the turbo when you start her up after turning the fuel screw!!! In case of run away, this is the only way to shut her down.
solenoid
why dosent the fuel shot off solenoid work?
Often as not, when you turn the key off on a runaway the plunger tip will get shredded and the engine will continue to run.
The shutdown lever is also ineffective because the governor lever is already in the "defuel" position. A piece of wood or metal plate over the turbo intake is the best way to stop the engine. Do not try to use your hand or a rag.
12valvin
Jun 20, 2009 12:29 PM
TexasHardcore
Oct 26, 2004 05:43 PM
