turbo housing leak
turbo housing leak
Well I was under the truck and found a stream of oil (dry) coming from the exhaust side of the turbo so My guess is the turbo is about to quit, I saw this some time ago and noticed lower boost #'s lately. I don't want it to start leaking inside and feed itself until it blows up so how hard is it to rebuild one of this? This is a 89 CTD with a 5spd behind it turbo setup I don't know what size is the housing but maybe that doesn't matter when rebuilding the guts. Can the home mechanic do this or is something better done by a shop?
Thank You.
Thank You.
Ok I read the sticky for the HX35, seems pretty straight forward. Where is a good place to get this kits, I see the one on the sticky just asking in case there is a better option.
Thank You.
Thank You.
Found this one, is this the turbo I have? I will check the sticker on it but I'm not really sure if it is the factory turbo, the truck has a banks IC and intake horn I read somewhere this kits also came with an upgrade or different turbo, how do I tell the difference?
Thank You.
Thank You.
The turbo gurus must all be plowing snow; there are multi threads on guys pounding them apart. I've never had to touch mine but will if necessary. Do a search on "turbo rebuild" if no one keeps chiming in.
let me ask you this, do you idle a lot? we see this "turbo slobber" quite a bit on our cats that idle a lot. most of the time it is not oil at all but unburned fuel mixed with soot leaking past your gasket. the lower boost numbers may be due to the gasket leaking--worth looking into. i would diagnose the problem before just going into a turbo rebuild unless you just want to do it and this is the excuse.
The stain this time was a little wet and it really looks like oil plus is coming from the housing right where the impeller is, where the V clamp connects the housing and the exhaust pipe.
If the turbo is fine -which btw a year ago I pulled the compressor housing and tried to move the shaft a little bit and felt ok to Me- I rather leave it alone, but then again I don't want it to get worst and one day have a runaway.
Thank You.
Shouldn't matter on idling. Turbo should not leak seal are bad in side. There isn't much to rebuilding the turbo. Only thing is ballancing the shaft would be the hard part. but it can be done.
Thank You.
Greg
I could well be wrong, but I though there was only one type of failure you needed to balance the shaft because of... only I can't remember what that failure is! Otherwise, to the best of my knowledge rebuilding a turbo is basically replacing bearings/O-rings and gaskets. Which I've done one of, and it took me an hour to do, so it's pretty darned easy. If a goat like me can do it, anyone can.
ajbirken
09-06-2006 12:11 AM
95black2615
07-21-2005 09:06 PM
j
01-09-2004 08:19 AM
HOHN
12-07-2003 02:07 PM
