turbo housing
Old Mar 23, 2014 | 02:47 AM
NE frmhnd's Avatar
turbo housing
I'm buying truck parts when my tax returns come in. I want the 16cm housing for faster spool-up, right?
Tried search but got results mostly for newer stuff.
Old Mar 23, 2014 | 08:03 AM
Not really sure what your question is, but this is been on my "wish list" for quite some time now.
http://www.ebay.com/itm/280615242496...84.m1423.l2649
Look quick, as it will disappear soon.
Old Mar 23, 2014 | 09:18 AM
NE frmhnd's Avatar
Yeah, that's the quicker-spooling one, right?
Old Mar 23, 2014 | 09:44 AM
mknittle's Avatar
Stock on a 1990 is 18 cm I don't think you would see much difference with the 16cm. I am going to try a 14cm on mine when I get around to it.
Old Mar 23, 2014 | 10:58 AM
cougar's Avatar
The smaller you go, the higher and faster your EGT will climb. If I had it to do over again, I would have kept the 18. Better money spent would be on a 60mm compressor upgrade.
Old Mar 23, 2014 | 08:32 PM
enydick's Avatar
i had a 14 cm housing with a 60mm compressor upgrade and loved it had to be easy sometimes on egt also layed down 337 856 with that turbo
Old Mar 23, 2014 | 10:31 PM
Montana2x2's Avatar
I agree, especially with an auto trans you only have to spool it once not every gear like a manual trans. If you use the truck for heavy loads I'd stay away from the smaller turbine housings.
Old Mar 24, 2014 | 12:02 PM
simplysmn's Avatar
I have a 12 WG housing on my crewcab and it will get a little warm if I pull a big hill but on the flat ground it will run good .I still have my 16 if I have to go back to it thou .
ajbirken
Sep 6, 2006 12:11 AM
95black2615
Jul 21, 2005 09:06 PM
j
Jan 9, 2004 08:19 AM
HOHN
Dec 7, 2003 02:07 PM
dieselinveins
Nov 6, 2002 09:17 PM
