Turbo Exhaust Housing Question
Old Jul 17, 2006 | 04:54 PM
justagoodolboy's Avatar
I am a new user in the past month, and have been doing alot of research on the site. It is impressive the amount of info available. I will be ordering an HTT Stage III compressor upgrade & 16 cm exhaust housing depending on the responses. It is my goal to use 4" downpipe from the turbo for my exhaust. I understand there are diffrent 16 cm housings, some with a 3" outlet and some with 4" correct? It is my understanding the 1994 thru 1998 trucks have the 16 cm housings with the 4" outlets, so that would be the one I am after correct? If so, is there an aftermarket 4" downpipe available that I should look into that works well with the 1st Gen? Am I going about this upgrade in the wrong way? Thanks for everyones responses is advance.
PS - I am interested in stout pulling, as I routinely drag around 15 to 20+ thousands pounds of hay.
Jeff
Old Jul 17, 2006 | 05:08 PM
JD730's Avatar
As far as I know the 16cm housing for the WH1C/HX35 are 3" outlet only. You'd have to go to a HX40 or one of the Switzer S300 built ups to get a true 4" outlet.
1994 to 1998 trucks came with either a WH1C(94 and 95 trucks) or HX35(96 to 98) with a 12cm wastegated exhaust housing. None of them are 4" outlet, infact stock exhaust was 3".
Old Jul 17, 2006 | 05:13 PM
ChrisLib's Avatar
All OEM turbo outlets are 3inch. The 4 inch outlet stuff is all aftermarket/performance stuff. 4 inch DP`s can be had from a bunch of places, some require fab/welding some don`t, I`m sure someone else`ll chime in. I have a 4in from Rip Rook http://www.sourceautomotive.biz/sa_dodge-exh.htm
It required welding on the 3to4 in adaptor (pic in my gallery) but I think Stan`s (don`t know the URL) comes ready to install. As far as an exh housing it depends how the truck will be used mainly. IMO for a 5 speed thats doing mostly low speed grunt work go for a 12cm gated housing.
Old Jul 17, 2006 | 05:22 PM
Dusty Ratcliff's Avatar
another vote for the 12cm gated, had one on my 90' & the spool up was awesome, & they are easy to come by too, I have a couple laying around myself, as well as probably a hundred other users on this board!! LOL but I'd consider the 12cm, I really liked it on my 90', Dusty
Old Jul 17, 2006 | 05:28 PM
Falcon1's Avatar
And another for a 12cm.
Old Jul 17, 2006 | 06:07 PM
goodtyms's Avatar
I already had a Non-W/G 12cm and really liked it. Just swapped it for a W/G version of the same size, but am still taking it easy until I retorque the new head studs a time or two.
Old Jul 17, 2006 | 07:01 PM
JD730's Avatar
12cm like these other guys say, I took my 16cm off and it's not going back on that truck. Lights the turbo earlier, cleans the smoke up and gets her moving ealier with my tight torque converter.
Old Jul 17, 2006 | 07:54 PM
edwinsmith's Avatar
I went from the stock H1C with an 18 cm housing to the WH1C with the 12 cm WG. I drilled the center divider through the W hole to allow better flow for the front 3 cyls and added a boost controller. I'm happy as a clam with it. IMHO going to the 16 nonWG isn't worth it.
Edwin
Old Jul 17, 2006 | 10:41 PM
JD730's Avatar
The reason I swapped it because my Goerend torque converter is too tight to light the turbo early and clean the smoke up with the 16cm on it. With 5 trucks on the road it doesn't hurt to have an extra turbo around.
Last edited by wannadiesel; Jul 18, 2006 at 07:23 PM. Reason: response to ad removed
Old Jul 18, 2006 | 08:05 AM
More Info - I delivery this hay with 90%+ being just that - highway travel. Obviously I would like to be able to keep up with the flow of traffic. Will the smaller housing hurt me on the top end? I don't mind slow take-offs.....
Thanks for all the responses.
Old Jul 18, 2006 | 11:09 AM
i never seen any negative effects on the top end, the great thing about the 12cm on a 1st gen. is that w/out some mods the 1st gen 12-v's have virtually no top end anyway, I think mine would only turn around 2400rpm's or so (if that), so there isn't much if any way to hurt the top end, because the top end of the 1st gen's is still well within the effeciency (sp??) range of the 12cm housing, I think it's one of the best & most cost effective mods you can do to a 1st gen, but that's just my opinion, & based upon your everyday drive around/tow rig, not for the high hp guys, but just as a good all around mild bomb , you can't beat it, well worth the time/$ it takes to swap , Dusty
Old Jul 18, 2006 | 12:48 PM
G1625S's Avatar
The 12cm won't really become a restriction untill you add a lot of fuel, which, if you do to a tow rig, really means you need a bigger turbo anyway. While the bigger housings do have more 'top end', a 16 or 18 will have you so hot by the time you get up to speed that you won't be able to lean into it in top gear to maintain speed anyway. Up to about 260/550 at the rear wheels, the 12cm (wastegated) simply cannot be beat.
Old Jul 18, 2006 | 03:54 PM
andyr354's Avatar
I would also like to goto a 12cm WG. Or a place to find one.
Reading though the responses here it sounds like it might really help with my towing EGTs. With the 18.5 if I get much under 1800 rpm I gotta let out of the throttle or shift down because the boost starts to drop off.
What is the "boost controler" for the WG housing that was mentioned in this thread?
Andy
Last edited by wannadiesel; Jul 18, 2006 at 07:24 PM. Reason: Ad removed, use the classifieds
Old Jul 18, 2006 | 04:04 PM
G1625S's Avatar
A boost controler refers to either an adjustable bleed or adjustable restriction in the boost line that triggers the wastegate controller. Most stock Dodge/Cumminswastegate controllers open at 22-ish psi. By adding a bleed or restriction to that line, the opening point can be altered and more boost can be made While it's true 22psi is roughly the sweet spot for the H1C, we tend to gain more than we lose by upping the pressure to about 32. The controllers are available on e-bay for a few bucks....there's lots of different ones. Dave will chime in with a link before long.....
Old Jul 18, 2006 | 04:16 PM
ruquik's Avatar
What kind of housing would be on a 24v with an hx-35W, that is in a UPS truck
