Turbo Exhaust Housing Question
Old Jul 20, 2006 | 08:24 PM
  #31
G1625S's Avatar
You're an excellent candidate for the 12cm wastegated housing Waldo. It'll feel like you bought a new truck It's really the only housing that makes sense with the 5 speed...by the time you have enough fuel to overcome the 12w/g, you'll have wayyy too much for a 16 or even 18...and will be looking to step up to a completely different turbo anyway.
Old Jul 20, 2006 | 08:39 PM
  #32
whereswaldo250's Avatar
WOW!!!!!
That was fast Thanks
What exhaust company would be the best for this set up??? Oh and another question I can't read the ID plate on my turbo , so what turbo do I have exactly sorry for the stupid question but the manuel does not say I'm thinkin I have a hx-35. And is installation hard since I am new at this whole diesel scene??
Thanks
PS- sorry for butting into this thread I didn't to start another one
Old Jul 21, 2006 | 04:34 AM
  #33
crossy's Avatar
should be fine for guys putting out JUST 350-400HP though. LOL, crossy
Yes, they use the same shaft as an HX-35, so the extra load of the larger turbine and compressor wheels makes them fragile in comparison.
Old Jul 21, 2006 | 06:02 AM
  #34
ruquik's Avatar
Why would I need A 14cm WG housing and not just a14cm non-w/g housing?
Someone help
Old Jul 21, 2006 | 07:26 AM
  #35
JD730's Avatar
Someone help
With a wastegated housing you can regulate max boost and keep the compressor on the map. With a non-gated housing your at the mercy of your fuel settings and you right foot, with enough fuel it would be pretty easy to put the turbo into orbit.
Old Jul 21, 2006 | 02:10 PM
  #36
Will the 12cm w/g housing work with my stock turbo on my 92 or do I need a new turbo also? What is the difference between the h1c and the wh1c turbo?
Thanks
Old Jul 21, 2006 | 02:53 PM
  #37
JD730's Avatar
Thanks
It will bolt right up to the turbo. The only difference between the H1C and WH1C's that where used on these trucks that I'm aware of is the WH1C has a map enhancing slot cut in the compressor housing and the W stands for wastegated.
Old Jul 21, 2006 | 04:08 PM
  #38
90firstgen's Avatar
Originally Posted by ChrisLib
4 inch DP`s can be had from a bunch of places, some require fab/welding some don`t, I`m sure someone else`ll chime in. I have a 4in from Rip Rook http://www.sourceautomotive.biz/sa_dodge-exh.htm
It required welding on the 3to4 in adaptor (pic in my gallery) but I think Stan`s (don`t know the URL) comes ready to install.
Does anybody know the URL or company or anything for "Stan's" 4" downpipe? I'd really like to get a hold of one. Thanks!
Old Jul 21, 2006 | 04:51 PM
  #39
ChrisLib's Avatar
I think this is it
http://www.stans-headers.com/diesel.htm
Old Jul 21, 2006 | 05:28 PM
  #40
90firstgen's Avatar
That was it! I appreciate it. $185 for just a downpipe, but it could be worth it.
Old Jul 21, 2006 | 06:53 PM
  #41
The 12 cm will be better for you. I went from a 21 to a 12 and it was like getting a new truck.
Old Jul 21, 2006 | 07:48 PM
  #42
When I finally get one is there any fuel adjustments I have to to such as going from a lift pump tp a piston pump? I'v have been reading this thread about where to get them but I can't seem to find one with a w/g .
Thanks
Old Jul 21, 2006 | 07:51 PM
  #43
I forgot one other question it seems that alot of people are also running 16cm housings what whould that do to my truck?
Old Jul 22, 2006 | 06:27 AM
  #44
You don't need a piston pump until you have big injectors, the stock pump can keep up with the little injectors on a '92. No need to tune the injection pump if you don't want to, just changing the turbine housing will make the truck much more responsive.
A 16 cm would be an improvement over the 21 cm you have. It won't be as quick as the 12 cm, but it will be much better than that awful 21 cm.
Old Jul 22, 2006 | 06:28 AM
  #45
JD730's Avatar
It will help, you'll probably notice it more if you have the 21cm housing. I didn't really notice it on my truck when I went from a 18cm to a 16cm. The WH1C with the 12cm wastegated that wannadiesel sold me made a huge difference, that and it was already portmatched and had the divider drilled so I didn't have to do it.
