Truck Won't Shut off.
Old May 3, 2008 | 07:18 AM
swany's Avatar
Unhappy Truck Won't Shut off.
Hey DTR, Yesterday went to turn off truck, engine stayed running. I read a thread awhile back about the same thing, I found a two prong female plug hanging loose near the injection pump, but for the life of me can't find where it goes! It's a weatherpack connection and looks like it had been plugged in. I ended up smothering it last night but would appreciate any ideas, Thanks once again.
Old May 3, 2008 | 07:30 AM
JD730's Avatar
Shutdown solenoid plunger, probably has the rubber tip damaged. Its on the part with all the lines coming out of it, right on top.
That connector has nothing to do with it. Probably the water in fuel sensor.
There's a lever on the side of the pump, you can use that to shut it down.
Old May 3, 2008 | 07:31 AM
Power Ram 250 C's Avatar
There is a shutdown lever on the side of the ip to shut it down manually. Usually when the wire on the fuel shut off solenoid is removed the engine will die. Your solenoid must have died on you. The articles are in the sticky.
Old May 3, 2008 | 07:38 AM
JD730's Avatar
I doubt it, a dead solenoid is a no start condition. It probably ate a piece of rubber off the plunger.
Old May 3, 2008 | 08:00 AM
swany's Avatar
Ya, it will start right up, the water sensor is still in place, I just had never seen the other connector there, but then again I was not looking for anything.
Old May 3, 2008 | 08:21 AM
swany's Avatar
Right on top? is there two other single wire connections on it?
Old May 3, 2008 | 11:00 AM
SmokemS's Avatar
mine just did that two weeks ago.....so the little lever on the side of the pump will shut it off .......so i just bought a carb puller line( whatever you call that thing) and hooked it up and i just pull the cable and she shuts off.....its like a big truck now
Old May 3, 2008 | 12:12 PM
BearKiller's Avatar
Look at the rear of the pump, at the big square block where the six injector-lines are screwed in.
Now look right on top of this square block, just behind that flat steel bracket; there you will see a screwed-in plug, with an electrical terminal on top and a wire plugged to it; THAT is the shut-down solenoid.
Due to space limitations, you cannot screw it out with a wrench; some have managed to un-screw it by carefully tapping at the base with a chisel.
Screw it out and fish all of it's parts out of the hole; there should be a rubber-tipped plunger and a spring.
Put the plunger and spring in the glove-box and screw the plug back in.
Now, connect the cable mechanism of your choice to the shut-down lever on the driver-side of the pump and mission accomplished.
Old May 3, 2008 | 01:50 PM
Montana2x2's Avatar
If you the the throttle cable bracket off the engine you get good access to the solenoid, 10-15 minute job to swap out the solenoid/plunger.
Old May 4, 2008 | 10:36 AM
swany's Avatar
Well alright I'll get to work on it, probably try to repair plunger in case I want to sell it someday, otherwise I like the Cable idea. Thanks Again for the knowledge.
Old May 4, 2008 | 04:41 PM
There's a VW parts supplier selling them for around $10 if you wind up needing a new plunger.
Old May 4, 2008 | 04:58 PM
daking's Avatar
dont worry it happens to alot of trucks, like mine, but your not in bad shape yet...
when you have to hook up a switch to start the truck off then you might get worryed, like mine
Old May 4, 2008 | 08:49 PM
swany's Avatar
Got er done, ground down the plunger, it hade a big chunk missing. For now it works again, if it does it again it's, pull cable time!Trying to keep er user friendly right now, the wife likes to use it sometimes. Thanks for the many replies.
Old May 4, 2008 | 09:59 PM
921stgen's Avatar
I bought one from dieselvw.com for $10 and $4 shipping for a truck I sold the buyer wanted it back to stock for his kid.
Old May 4, 2008 | 10:30 PM
racerdude_9's Avatar
when i bought my 91 it came with a rig saver on it. its gonna be handy for turning in the fuel screw. and if this issue ever shows up. it hasnt happened yet.
dkimmel
Jan 3, 2011 10:54 PM
randyswelding
Feb 9, 2009 10:40 PM
wedgepower
Feb 28, 2007 11:01 PM
wedgepower
Feb 28, 2007 05:57 PM
ddog87
Aug 2, 2006 03:40 PM
