Truck is still running badly
Old Dec 20, 2008 | 07:43 AM
77machomopar's Avatar
As in my previous thread my truck starts fairly easy but will smoke a blueish white smoke really bad and miss and sputter . It runs fairly smooth at an idle but will run like *#@! when any amount of throttle is applied. I did find a couple weeks ago that my injection pump was loose and could move around. Could my truck be acting this way cause the timing got retarded? Or is it like everyone i talked to and is an injection pump.
So far this is what i did to try to fix this.
I put a new lift pump on that didn't help, Ran a clear hose to the IP inlet. Pressurized the tank found no leaks, replaced my high pressure lines, replaced my steel return line from the IP to the Tee fitting on the back on motor(it was rusty and broke) I ordered the leak down adapter to do a leak down and compression test. I am going to try and upload a video and let you guys hear and see this thing. Thanks
Old Dec 20, 2008 | 08:18 AM
archer39's Avatar
retarded timing will make it run bad. i think i remember you saying that it was on the factory mark though. if that is the case i would not think the timing would have anything to do with it, assuming that the previous owner did not advance the pump a tooth in the case.
was this a gradual problem or did it happen all at once?
also, have you changed out the fuel filter? if you did not while your in there i would take a look at the fuel heater gasket. they are a common leak.
Old Dec 20, 2008 | 04:39 PM
It started almost instant it wasn't gradual really. I am pretty sure i remember putting the timing to the factory mark but that doesn't mean its not bumped inside the case like you said. it could have even moved when the pump was loose cause it would move around quite a bit. I change my fuel filter back in September. i am going to check that out. I still think that it is something air related cause it will clear up and run fine, but it might take up to an hour to clear up.
Old Dec 20, 2008 | 07:18 PM
Are you seeing air in your clear hose?
Did you put the pump back at the stock match marks when you tightened it down?
You're on my way to Cabela's...
Old Dec 20, 2008 | 08:48 PM
I only stuck the hose from the inlet port on the Ip right into a can of diesel there was only a couple air bubbles but they got worked out quickly and still ran bad. i am 99% sure i put the lined up the marks. Yes i am on the way to to Cabelas. I can still drive the truck but it takes a while to be able to be driven.
Old Dec 20, 2008 | 09:12 PM
archer39's Avatar
if it did not clear up with a line directly into a can of diesel then it has to be after that point. how are you injector lines and injectors? i would also make sure that your 100% sure the pump is back to the factory mark.
Let me know if you need anything. I too will be heading up to cabelas this week for a little last minute Christmas shopping (and some stuff for myself ) and could swing by.
Old Dec 21, 2008 | 06:52 AM
I am going to pull the injectors off and get them pop tested and make sure none of them leak. I'll let you know if i need any help Archer39. Thanks for the offer.
Old Dec 21, 2008 | 09:33 AM
boostedve's Avatar
make sure the injector lines are tight on the back of the pump...
Old Dec 21, 2008 | 12:53 PM
I check the injector lines and the factory timing marks. They are all good. my pump is within the serial number range for the recall so i am going to check on that Monday. I am still convinced its air because when the truck runs for awhile it clears up. If i turn it off and it cools for about .5 -1 hour it misses but only for 1-2 minutes.
Old Dec 21, 2008 | 12:54 PM
Advance Timing... Just a thought
Another thought... should i try to advance the timing. Maybe that will do something. Just a thought.
Old Dec 21, 2008 | 12:55 PM
Can't hurt to try it.
Old Dec 21, 2008 | 12:58 PM
OK i'll try it. how far so i advance it?
Old Dec 21, 2008 | 01:18 PM
archer39's Avatar
1/8 of an inch should be good
Old Dec 21, 2008 | 02:46 PM
! am puzzled...
The factory timing marks were lined up perfectly. So i advanced 1/8 inch. It fixed my problem it runs better then before this all happened. i don't know why the factory marks weren't enough timing but it runs excellent again. Thanks for everyone's help and offers to come and take a look.
Old Dec 21, 2008 | 03:45 PM
archer39's Avatar
that's good, glad you got it fixed!!
southpawslingr1
Feb 26, 2012 11:33 PM
hovisimo
Feb 16, 2008 05:05 PM
fubu2
Mar 23, 2007 08:47 PM
rickyd
Mar 11, 2003 09:16 AM
Shovelhead
Feb 20, 2003 03:16 PM
