truck overheats
Old Sep 10, 2008 | 05:59 PM
robb152's Avatar
Exclamation truck overheats
my 93 d350 overheats at highway speeds of 90 to 100 mph egts are at 950 to 1000 any ideas or is this the nature of the beast
Old Sep 10, 2008 | 06:01 PM
How old is the radiator? It shouldn't run hot even at those speeds unless you have a big ol' slide in camper on the back.
Old Sep 10, 2008 | 06:07 PM
robb152's Avatar
factory.... nothing blocking it either
Old Sep 10, 2008 | 06:08 PM
I suspect it's pretty cruddy inside, 15 years is an awful long time for a radiator.
Old Sep 10, 2008 | 06:12 PM
robb152's Avatar
rad been flushed.. cores look soild.. is there any after market rad
Old Sep 10, 2008 | 07:53 PM
IRoss's Avatar
Is that empty? Try a real temp gauge..My factory gauge is a pos and it had me fooled for a while when I first got the truck ...Does your water pump weep out the bottom when it gets hot? Thats a pretty good sign that the pumps no longer efficient..i spent the money on a new rad when all I needed was a pump/tstat...much cheaper..
Is it getting hot enough to boil over?..If the fan spins by hand when it gets hot you could probably use a new one of those too..good luck,
Old Sep 10, 2008 | 08:01 PM
gear jammer 91"'s Avatar
I had a truck that was doing the same thing, it ended up being because all the fins on the back of the radiator down by the bottom where rusted out or missing. Everything looked good from the front and inside the cap, the bad area was out of sight. Might be worth checking.
Or you could do the speed limit.
Old Sep 10, 2008 | 08:41 PM
Montana2x2's Avatar
2nd good gauge before you throw a lot of $$$$ at it.
RobG
Feb 22, 2014 10:24 AM
Ranchhand Ram
38
Jan 23, 2014 10:53 AM
dart4forte
Oct 28, 2006 03:09 PM
aggiehorsepower
13
Sep 22, 2006 09:53 PM
Herve
23
Mar 7, 2004 10:24 AM
