Changed Coolant / Now Overheats!
Old Feb 1, 2014 | 05:15 PM
RobG's Avatar
Pulled the lower radiator hose and dumped the coolant today. It hasn't been changed since the truck was new (98,500 miles). I also dumped the overflow tank. Refilled with about 2.25 gal of fresh Prestone 50/50 and a bottle of DCA4, and dumped another gallon into the overflow tank.
Went for a drive. Headed up a hill with a nice twisty road near home... slow, twisty. I've driven it many times without issue. This time when I reached the top, I was at 262 deg according to my Ultragauge. Ugh. Fortunately it was downhill most of the rest of the way home and it cooled back off. It did get back up to about 242 just before pulling into the driveway, but I let it idle for a while and it got down to 210 or so before I shut it off.
What do you think? Stuck thermostat? Do these things need to be burped?
Rob
Old Feb 1, 2014 | 05:24 PM
jhenson's Avatar
You have an air pocket.....pull the heater hose coming out of the head to purge it.
Sent from my XT1080 using IB AutoGroup
Old Feb 1, 2014 | 05:28 PM
RobG's Avatar
Thanks! Okay silly questions... where exactly is that hose, and once I do that, then what? Run the motor?
Rob
Old Feb 1, 2014 | 06:13 PM
Colo_River_Ram's Avatar
With age comes the cage
Rob,
This is the best thread you will find on the subject:
https://www.dieseltruckresource.com/...=coolant+flush
Old Feb 1, 2014 | 06:39 PM
rockcrawler304's Avatar
It does sound like an air pocket to me too.
A little late but the coolant you used is not the correct one. These engines require a HOAT coolant like the Zerex G-05
Old Feb 1, 2014 | 08:06 PM
RobG's Avatar
Thanks guys, got it all worked out.
And no it doesn't require HOAT. Did a lot of searching on that topic.
Rob
Old Feb 2, 2014 | 12:20 AM
47Dodge's Avatar
Rob
Better read your owners manual. Says to put the HOAT type in. Using propylene glycol is not recommended as the vehicle isn't designed to use it.
47
Old Feb 2, 2014 | 11:52 AM
MikeyB's Avatar
BTW, no need for DCA4. That is a requirement for wet sleeved bores. Our engines are 'parent bore'.
Old Feb 2, 2014 | 04:04 PM
Rob
Wrong!! But it's your engine. Damage it if you want.
47
This ^^^
Old Feb 3, 2014 | 07:24 AM
Pull Dog's Avatar
Very true, this is the best write up on changing coolant....yes you have an air pocket, read the instructions below. I put my coolant in until it ran out of this hose and there were no problems. Engine should be off.
I agree with post on HOAT coolant for these engines! My research convinced me it was the only one to use. NAPA is the only place I could find it. I'm sure there are other places.
Old Feb 21, 2014 | 03:42 PM
bonus's Avatar
RobG, just like ^^^^ all the above typed, get some Zerex G-05.
Old Feb 22, 2014 | 10:24 AM
railroaderone's Avatar
or he could pull one of the pipe plugs on the head that requires a 3/8 drive ratchet to bleed the air out fill it till coolant comes out.
and deffentifly HOAT
Ranchhand Ram
38
Jan 23, 2014 10:53 AM
Mark Hodowanec
Aug 17, 2009 11:56 AM
robb152
Sep 10, 2008 08:41 PM
dart4forte
Oct 28, 2006 03:09 PM
aggiehorsepower
13
Sep 22, 2006 09:53 PM
