Transmission Return Line
I'm trying to replace this patched up mess of cut and spliced transmission lines on my truck with new ones and replace the 3/8" pipe oil cooler with a new 1/2" pipe cooler. So far I've located new line for pressure side and the cooler but haven't found the return line so far. Anyone know where I can get one?
I used the "Push-lock" fittings and hose. Rated to 300psi and 300F. Available in 1/4" 3/8" 1/2" etc. I used the 1/2"
Once you push it together, it's not coming apart. You can literally hang from it. No clamps, brass fittings so no rust, very flexible and kink resistant. Can't beat it.
Check with your local hydraulic supply shop, they should have it.
Rick 12v CTD
Sep 23, 2011 05:21 PM
Scotts_D250
Jul 10, 2011 01:05 AM
ctd4stan
May 18, 2009 02:56 PM
Tiara3100
Jan 14, 2008 10:06 AM
hellotbone
Feb 26, 2003 03:28 PM
