Tranny Cooler pan
Old Aug 12, 2011 | 05:29 AM
Tranny Cooler pan
Anyone using a tranny cooler pan ?
Amazon Amazon
This one from amazon looks like a good deal, and with the sump extender kit, it's under $200
Thoughts ? Concerns ? Experiences ?
TIA
T.
Old Aug 12, 2011 | 05:42 AM
ChrisLib's Avatar
I`m shopping them myself, looks ok but those tubes worry me as far as getting filled with dirt/crud/winter salt and the ensuing rust. Seems to me it`s one more thing to have to keep an eye on.
Old Aug 12, 2011 | 06:30 AM
Yeah, I thought of that myself, but I don't go off roading.... so the most I'll be getting in there is the occasional squirrel that kamakazi's my truck.
I just ordered it, so I'll be posting my impressions when I get it.
T.
Old Aug 12, 2011 | 08:25 AM
sshort's Avatar
I run one of those but the older model it is realy nice I think if i remember it holds a additional 4-6 qts of oil I think when i changed mine I had to put aprox 12qts of oil to bring it back to full if you can find the older model it is silver finish & only cost about $89.00
Old Aug 12, 2011 | 06:45 PM
rebal's Avatar
I have one on an older truck (83) that has never pluged up But i wonderif it even works cuz that truck trans gets hot when towing
Old Aug 12, 2011 | 10:07 PM
DPFservice's Avatar
I have the same one on my truck. It dropped the temps on the freeway to around 100 degrees and around town runs 135 that's with the probe in the pan. I know it's a better buy then the pans double the cost.
Old Aug 13, 2011 | 07:50 AM
#2isgreen's Avatar
Unless it's untaxed, then it's red.
I have this pan too. After two winters of mild in Maryland its got some rust. No.e was unfinished. That one in black looks like like it might stand up better. I don't have a temp gauge but it makes me feel better.
I think mine took 17qts to fill. (With engine running in neutral)
Old Aug 13, 2011 | 08:55 AM
AUGIE DOG's Avatar
Did you install the filter extender that is offered on Amazon?
Old Aug 13, 2011 | 12:14 PM
zack_76401's Avatar
From: Lingleville TX but active duty Air Force all over the world currently
I have that exact pan, ordered the filter extender also. The screws supplied with the extender weren't long enough so i left it off and just put a filter in the stock location.
I live on dirt/kileche road and it doesn't get clogged up. Much nicer and cheaper than a 300.00 pan. Mine is the black one and I have no rust.
Old Aug 13, 2011 | 06:26 PM
Just received the pan and extender. Looks like a nice unit.
Doesn't come with a filter, so I have to pick one up.
T.
Old Aug 13, 2011 | 08:27 PM
jerseybud's Avatar
Derale makes some nice stuff. I've had one on my 4l60e in a s10 since 2003 and no cracks, no rust. Can't comment on temp differences.
Old Oct 20, 2011 | 04:37 AM
The pan and extender are installed.
Really nice unit, with a trans temp port, and drain plug (magnetic) installed already.
Went in relatively easy, although I had a few bolts stripped out of the trans that need to be helicoiled next time the pan gets dropped.
it appears the previously the trans bolts were overtightened.
No leaks, as I just used longer bolts to catch the remaining threads on 3 holes
Best thing for you guys, is the price came down about $30 since I bought it.
T.
Tank_66
Jan 11, 2012 10:12 AM
high bid
Aug 2, 2007 06:08 PM
tex23455
Jul 25, 2007 02:31 AM
MrKen
Nov 23, 2006 03:19 PM
bostongsx
Sep 25, 2006 11:25 PM
