Tranny and belhousing
Can someone give me some info,doing a conversion from auto to standard on 93 d250 diesel,Does the belhousing that had a getrag on be used for an NV4500 trans. I know the input shaft has to be changed,anything else?
Bell housing or adapter plate that the starter bolts too?
Advanced Adapters has a custom bell housing for sale so you can re-use your 1st gen adapter plate and starter [auto OR manual] for the NV-4500 swap, BUT you need the Getrag clutch fork to make it all work.
A diesel NV-4500 has the same input spline as a Getrag...
fremec (11-24-2018)
Don't forget about the cross member, there are differences between the 2.
fremec (11-24-2018)
Yeah the NV4500 2wd conversion is a lot tougher to get a working tranny cross member....mine was a large piece of channel across the frame rails with the stock NV4500 2nd Gen tranny mount. I tried modifying a 1st gen 2wd unit to use on the NV4500 but could not make anything work, even tried cutting and piecing one together....again not go.
I have done lots of auto to manual swap on 1st gen 5.9 Cummins trucks.... never had that issue.
Installing a late 70's 360 motor out of and auto in my old '69 manual shifted 'Cuda ...That I had an issue with the pilot bearing fitting in a slightly smaller pilot bearing hole.
I would not trust these "experts" info.
Edwin
The 1st gen flywheels usually come with a bronze pilot busing.
The 2nd gen or aftermarket flywheels come with a needle bearing in the flywheel.
I just did the reverse of what you are doing and had to source a different motor plate (bell housing) for the A518. The manual plate is deeper. I have the fly wheel and motor plate if you are interested. To be sure they are right for your application I can get the part number off the plate if needed. Good luck with your swap.
