Towing
Old Apr 18, 2008 | 12:40 AM
red_neck1984's Avatar
Towing
Ok so I got my trailer all loaded up 24FT ENCLOSED 3680# quad 700,race car 2200 generator and spairs 600 =7180 So now when towing out of the hole it feels ok but as soon as i hit a hill it kicks out of overdrive and i put my foot to the floor and i can hold 85-90 km/h and no more.I try to pass and nuttin there no smoke no nuttin it just feels like i should have more on tap but i dont
Old Apr 18, 2008 | 01:43 AM
mullishacrew's Avatar
is your transmission a 518 or 727? i had that problem with my truck but without any load, turned out to be burnt up clutches witch caused some major slipping.
Old Apr 18, 2008 | 01:48 AM
Thats a good thought i hope its not that
Old Apr 18, 2008 | 02:31 AM
Alwaysworking's Avatar
alwaysonDTR
did it just start?
i mean did it smoke before when towing in the same condition?
if so whats changed since then?
did it always kick out of over drive?
Old Apr 18, 2008 | 04:55 PM
Put in a 3200 RPM spring and you won't need no stinkin' overdrive.
Old Apr 19, 2008 | 03:40 AM
No this is the first big laod with the new car and all the gear,and i never have no more then a hazz when it kicks down i thought i should have a black cloud.But i think im de fueling because if i can get it into overdrive it starts to pull more i feel it so ill try it agian an get some boost numbers and then ill go from there.I need a fuell pin and 3200 spring and it should help right ?
Old Apr 19, 2008 | 04:48 AM
When it kicks down, the engine is already under load and the turbo is making good boost, that is why you aren't getting a cloud of smoke.
The 3200 RPM spring will let you pull faster in direct drive, you should be able to hit 110-120 kph if you wish to go that fast.
If your EGT's are OK, go ahead and add the fuel pin, that will help it pull harder in every gear. Have you rotated the stock pin to the deep side yet?
Also check the TPS adjustment. It might just be set to kick down too easy.
Old Apr 19, 2008 | 06:35 PM
yes the fuel pin is turned and ill check the tps thanks
Old Apr 19, 2008 | 09:00 PM
bigredbrick's Avatar
FWIW, 35s and 3.54s aren't optimal for towing. I've got 285s and 3.54s and when I tow my travel trailer, about 6000#, there's many grades that I'm down to 45mph and that's all she's got! I've got the go pedal mashed to the floor so hard my leg gets tired! But then, my truck's pretty much stock. Also, you want to keep it out of OD when the revs drop below 1600 or you could fry the OD. A performance converter could help so the power gets to the pavement.
Old Apr 19, 2008 | 10:00 PM
torquefan's Avatar
I agree with checking the TPS. I don't think it should be kicking out of overdrive at that speed- third gear will put you too close to redline and you won't have any room to accelerate.
Old Apr 19, 2008 | 10:22 PM
rebal's Avatar
35 +3.54 stock converter = for towing
Old Apr 20, 2008 | 01:10 AM
well then i gess i will sell the 35's or re gear to 4:11's
Old Apr 20, 2008 | 01:30 AM
alwaysonDTR
stock hight for towing i think is the best.
Old Apr 20, 2008 | 12:07 PM
rebal's Avatar
If you haven't already ditch the stock T/C and get a tighter one it makes a BIG improvement. If I remember right ( getting old) the stock converters only put 60% of the power to the ground
Old Apr 22, 2008 | 11:47 PM
cLAYH's Avatar
If you want to tow get rid of the 35s or regear your truck. You are losing all of your torque to those big wheels.
X2 on the TC as well. The stock unit sucks.
BTW how long have you had your truck and where did you buy it?
edonald849
Feb 22, 2009 04:44 PM
Trusty Steed
Feb 24, 2004 07:11 AM
gunracer1
Mar 21, 2003 05:14 PM
NJDiverDan
Mar 19, 2003 06:46 AM
furious70
Mar 13, 2003 06:26 PM
