Took my AC compressor off... There has to be an easier way.
Old Jul 12, 2011 | 01:46 PM
1$Chuck's Avatar
I'm working on a R134 retrofit.
That compressor has more steel and bolts holding it onto the engine than what they used to mount the engine into the truck. After much cussing and sweating I finally got it off so I could drain it.
I ended up having to remove my oil filter and slide the compressor back so i could take the lines off and then drop the compressor out of the bottom. Of course this was after I removed about 8 really tight, over kill sized bolts. I'm not looking forward to putting it back this way because getting the lines back on is really going to be a PITA.
So how should I have taken it off?
Old Jul 12, 2011 | 01:53 PM
maybe368's Avatar
According to fsm...
remove belt
discharge system
remove lines
cap lines
remove 2 capscrews that connect to water inlet bracket, in front
remove 2 capscrews from bracket in back
spin compressor and remove
all done from below
sounds like you removed the brackets from the block...Mark
Old Jul 12, 2011 | 01:58 PM
1$Chuck's Avatar
Well, there's really two brackets. I took the one that the back of the compressor mounts to off. Other than that, I pretty much did what they said.
Its a better man than me that can unbolt those AC lines from the bottom side, and doing it from the top is pretty hard unless you pull the oil filter.
Surely Chrysler wouldn't have understated the proceedure
Originally Posted by maybe368
According to fsm...
remove belt
discharge system
remove lines
cap lines
all done from below
Old Jul 12, 2011 | 02:07 PM
maybe368's Avatar
I added the from below part and wasn't thinking about the lines at the time...My bad ...Mark
Old Jul 12, 2011 | 05:38 PM
MoparMarv's Avatar
I remember 4 really long 1/4 or 5/16 bolts that broke when I took mine out. I had to drill a hole in the compressor thru the bolt so I could get it off. I was replacing it anyhow. Really tucked in the frame rail and the bolts had to go in before you put it up there as I recall.
Old Jul 12, 2011 | 07:06 PM
jimbo486's Avatar
The non i/c compressor is definitely mounted oddly! Much like the way you removed yours, I remember fighting with mine for a little while. Luckily I was doing all this while replacing a head gasket so my oil filter and other parts weren't in the way. I don't understand why that design when a year later, in the i/c models, they changed to a 4-bolt, square pattern. Compared to mine, the i/c compressor would be a breeze to remove!
Old Jul 17, 2011 | 12:13 AM
I swapped my 89 motor over to the IC style, Sanden A/C compressor. Simple and cheap. I couldn't find a C171 Diesel compressor anywhere, and if I had it would have cost me about $5-600!! I got the engine bracket, new Sanden A/C compressor all for under $200. You will need to run new A/C lines though if you go this route.
Here's what I did....
https://www.dieseltruckresource.com/...c-t289065.html
Old Jul 17, 2011 | 02:21 PM
Rampage1967's Avatar
I believe that the Cummins is all metric which would mean those are metric bolts.
I have found that 5/16 will screw on to that particular size with the results you mention. (8mm i think)
The threads will be off just enough to make them tight.
Evildiesel
Feb 3, 2009 01:27 PM
dslpwr81
17
Apr 21, 2008 06:22 AM
fabjunkie
Jul 4, 2007 10:16 AM
Usta HaveA Hemi
Aug 24, 2005 01:10 AM
Crabjoe
Jan 11, 2004 08:21 PM
