timing bump egt drop
Old Dec 19, 2007 | 03:11 PM
Dean Snow's Avatar
so whats the normal egt drop after the timing bump,
im going to bump my timing since my pryo broke and im still waiting for it to be shipped here
just figured id see if it was even worth while
Old Dec 19, 2007 | 04:30 PM
flashgordon's Avatar
When you bump the timing, egts go down but actual piston temp go up!!!!!!!!
Fuel burn in the cylinder longer...............
Something to think about before you do it.
removing and plugging you boost line to you IP would help egts a lot............but you would suffer a power loss also.
Flash
Old Dec 19, 2007 | 05:06 PM
Free89W350's Avatar
Flash
I agree with this idea I have done it via valet switch. It was money well spent I went from pegging the 1600* pyro on wide open bursts to a max of 1000* on the same pedal pressure. The nice part about it is that I have all the power I want with the flip of a switch.
Ryan
Old Dec 19, 2007 | 05:13 PM
Dean Snow's Avatar
Thanks. I have the stuff to hook up a valet. I bought it back a while ago and didn't get around to it. So I'm going to hook it up now. So i don't want to bump the timing because it actually makes the cylinders hotter, but fools the pyrometer because the EGT's are lower correct?
Old Dec 19, 2007 | 05:21 PM
Free89W350's Avatar
If I'm not mistaken the timing bump gives it fuel sooner in the cycle thus keeping the fuel in the cyl longer. I have mine shoved to the head with the mods in my sig. now I need a larger turbo to help expell all the fuel I have.
Maybe santa will bring me that Gillett upgrade I asked for
Old Dec 19, 2007 | 05:56 PM
BearKiller's Avatar
Just how much power loss ??
If Santy Claws is not well-versed in diesel trucks, don't be surprised if you get a new razor, instead.
Old Dec 19, 2007 | 06:26 PM
G1625S's Avatar
It depends on pump settings and fuel pin orientation. The fuel pin translates directly (for the sake of conversation) to control collar travel. By stopping the cone from traveling down its bore, control collar movement on the plunger is limited by the same amount.
Old Dec 19, 2007 | 08:44 PM
Free89W350's Avatar
I didn't feel that much loss except that it doesn't pull quite as hard
Maybe I should say "Mrs. Clause" and she's more versed then she really wants to be
royta
Nov 6, 2006 08:19 AM
LCH
Oct 26, 2006 05:10 AM
GR40RCapri
Jun 25, 2006 12:53 AM
ouchman
Feb 15, 2006 04:47 PM
LanceD
Oct 25, 2005 11:16 AM
