timing advance
Old Oct 16, 2006 | 08:52 PM
  #46
flashgordon's Avatar
More timing will give more black smoke at low RPM.
Hmmm good to now!
Old Aug 30, 2009 | 06:38 PM
  #47
ez_lle71's Avatar
Would bumping the timing on a truck with factory injectors help? i have turned my pump up about 3 turns on the full fuel screw and have good throttle response now. But better throttle response sounds good. i do have quite abit of smoke under hard acceleration that would be nice to lighten up abit. thanks
ez
Old Aug 30, 2009 | 07:10 PM
  #48
Yeah, I'd recommend an 1/8" bump to anybody.
Old Aug 30, 2009 | 09:18 PM
  #49
ez_lle71's Avatar
Then that is what i will do.
Thanks wanna!
ez
Old Sep 6, 2011 | 07:28 PM
  #50
BearKiller's Avatar
92DODGE found that a ratchet strap is helpful for moving and holding the pump.
Can someone please show or tell me just how and where to connect this ratchet-strap ??
Thanks.
Old Sep 6, 2011 | 08:00 PM
  #51
Onemoparnut's Avatar
I hook it to the arc housing then put a board on top of the valve cover and run the strap over it to the passenger fender. There might be a video on you tube.
Old Sep 6, 2011 | 09:35 PM
  #52
BearKiller's Avatar
Wink >>> and that is exactly what i did <<<
THANK YOU
I headed back outside as soon as I read ^^^ this ^^^ .
I made a loop in a length of that orange plastic hay-bale string that is used on the BIG squares.
I placed this loop over the AFC housing and under the little "nub" that is just enough hook-shaped that it held my loop well.
Seeing as how I have FORD A/C right over the injection-pump, a standard non-Dodge manifold, and a huge air-intake, all in the path of the strap, I stacked four layers of 2X material on top of the valve-cover to get the strap to clear.
I believe the part about using the plank over the valve-covers was the best bit of your information, as it may have been midnight before doing thus dawned on me.
Once I got the ratchet-strap connected into my hay-string loop and hooked into the steerboard fender, it was a piece of cake to literally dial in the exact amount of rotation.
LanceD
15
Jan 12, 2004 05:23 PM
Davidp
Mar 16, 2003 11:40 AM
95ramtough
22
Jan 29, 2003 08:45 AM
Smokin
Nov 22, 2002 09:31 AM
