timing advance
Old Oct 13, 2006 | 08:43 AM
  #31
mooktank's Avatar
Ic ic. So that's a factory mark then. I assumed he chiseled that in for reference. Thanks.
Old Oct 13, 2006 | 08:51 AM
  #32
flashgordon's Avatar
I can't say for positive but the 2 pumps that i have replaced had the mark on them. when the rebuilt pump came back, and i had it in installed, and proceeded to remove the lock pin from the pump,those make lined up!
Old Oct 13, 2006 | 09:46 AM
  #33
BigWaylon's Avatar
I marked nothing...both marks were already there (the pics flash linked to are mine)...
before timing bump:
after timing bump:
Greg
Old Oct 13, 2006 | 11:05 AM
  #34
Redleg's Avatar
Just did mine. Took me two seconds to bend a 13mm wrench with a torch. The S wrench I used, hit the vaccum diaphram and wouldn't let me turn more than breaking loose.
Old Oct 13, 2006 | 06:34 PM
  #35
They were marked at the factory.
Old Oct 14, 2006 | 10:02 AM
  #36
Redleg's Avatar
Also, my bent 13mm got to the rear nut nicely without any extensions needed. Loosening the banjo on the AFC is all that was needed. I popped off the throttle linkage, opened the throttle a little for clearance, then a pipe wrench fit on the back of the pump nicely and made a quick job of turning the pump. Definitely sounds like a truck now.
Old Oct 14, 2006 | 04:43 PM
  #37
Boatnik's Avatar
Would that factory mark still be right if the pump is a remanufactured unit? My timing case looks like it was a test bed for chicken scratching. Too many marks to go by.
Old Oct 14, 2006 | 06:29 PM
  #38
DODGE 92's Avatar
timing
if you got too many scratches just bump it towards the motor and try it if it sounds like a 6.2 back it up a bit on mine a can barely get my hand between the pump and motor and so far so good
Old Oct 14, 2006 | 06:45 PM
  #39
No, that mark is only accurate for the original pump.
Old Oct 14, 2006 | 09:44 PM
  #40
Boatnik, i have only replace 2 of theses pump but both of them, when it was installed, lined up in line with the makes!
the first on I pinned before i pulled it and the sec one. the pump shop said that it wasn't necessary for him to rebuild it but was a good idea for me!
SO being the curious mind, I purposely turned the pump to the manifold and then pinned it!
Like i said, before, they both came back timed to the mark and them I unpinned it!
Old Oct 15, 2006 | 11:52 PM
  #41
pursuit989's Avatar
When changing the timing, will it poor out more black smoke??? Also, do you notice a big change in accelerating???
Old Oct 16, 2006 | 08:20 AM
  #42
Micaiahfied's Avatar
throttle responce should be better and smoke should be a little less if anything (i think) lol
Old Oct 16, 2006 | 08:43 AM
  #43
if you advance the timeng,less smoke more throttle responce!
Black smoke would only be if you when the wrong way!!!!!!(and it would be more white smoke!
Old Oct 16, 2006 | 12:06 PM
  #44
dpuckett's Avatar
I use a Craftsman 1/2in crow's foot with a 3" 3/8 extension on a 3/8 ratchet to reach the nut around down and around the corner. But, if you have an old/ cheap wrench to bend, that'll work just as well.
Daniel
Old Oct 16, 2006 | 04:56 PM
  #45
More timing will give more black smoke at low RPM.
