timing advance
Old Sep 7, 2005 | 12:53 PM
ihpower's Avatar
mine pops when cold as well
Old Sep 8, 2005 | 11:27 AM
Winr's Avatar
I just bumped mine up .187. Noticed the difference the first time out. 120deg lower EGT's, smoother throtle response and more "Diesel noise"
Old Sep 9, 2005 | 10:32 PM
DODGE 92's Avatar
pump timing
do a search on pump timing check out my postings on it yull get some nice tricks also check out my pics theres a few of the pumps
Old Sep 13, 2005 | 03:47 PM
LABBINSKI's Avatar
I am getting about 425 miles using 3/4's of a tank of fuel i have with tyhe help of a friend retimed mine twice as the dealer never did it properly when the pump was done under warrenty.The first time was to stock setting 1.25mm and the second was to 1.40 and have towed with no problems you really do need to check the timing just for the sake of knowing so you don't have to baby it
Old Sep 13, 2005 | 04:21 PM
fearthedeere's Avatar
i think im gonna advance mine when i get some shop time here at school. we have to use our own tools so wut will in need, 13mm s wrench what esle?
Old Sep 13, 2005 | 04:30 PM
ihpower's Avatar
thats it and maybe a ratchet strap or i used a big pair of channel locks to push the pump up
Old Sep 13, 2005 | 04:52 PM
Tool list:
13 mm "S" wrench
13 mm 1/4" drive socket
about a foot of 1/4" extensions
1/4" ratchet
10 mm box wrench
ratchet strap
Old Sep 13, 2005 | 07:07 PM
DODGE 92's Avatar
what wanna said
Old Sep 13, 2005 | 07:26 PM
csramsey640's Avatar
How do you know what is too far for us back yard types. Mine doesnt pop when cold, but when you walk around the front at any given idle time, you do hear more rattle than before, while cruising at 70mph, i dont seem to hear it. So I take it I dont have it too much?
Old Sep 13, 2005 | 09:06 PM
ihpower's Avatar
more rattle at itle is normal for timing advance.
Old Sep 14, 2005 | 05:41 PM
If it sounds like a Chevy 6.2 you went too far.
Old Sep 14, 2005 | 05:53 PM
charger 69's Avatar
So if I advance the pump it will raise the EGT when pulling the trailer on long hills?
Old Sep 14, 2005 | 06:32 PM
You have that backwards. Advancing the timing will lower EGT.
Old Oct 13, 2006 | 08:15 AM
mooktank's Avatar
How can you be sure yours is at the stock setting before you try advancing?
Old Oct 13, 2006 | 08:36 AM
flashgordon's Avatar
look here and go to post #230.........if the mark are lined up then it at stock timing.
https://www.dieseltruckresource.com/...59#post1163959
