time for air ride
Old Feb 11, 2007 | 10:59 AM
swank's Avatar
time for air ride
anybody come across any good links for making your own set up? or does anybody have any great ideas they've come up with? what kind of airbags should i use? where would the cheapest place to get them be? what's the coolest set up you've seen? thanks.
dave
ps, i'm talking about the kind with NO more leaf springs.
pps. i'm starting in the front.
Old Feb 11, 2007 | 04:19 PM
Ace's Avatar
Ace
Wow, that's radical. We talkin' 'bout the same truck that got wrecked last week? How'd that turn out?
Old Feb 11, 2007 | 05:50 PM
D/UNIT's Avatar
Swank, i thought your were just kidding about the air ride. guess not.
Old Feb 11, 2007 | 06:49 PM
swank's Avatar
that way i don't have to straighten the frame. just adjust it out with the cross brace.
Old Feb 11, 2007 | 10:06 PM
swank's Avatar
hasn't turned out any way yet. we'll see what happens.
Old Feb 11, 2007 | 11:12 PM
farmer0_1's Avatar
i am keeping an eye on this one.
Old Feb 11, 2007 | 11:19 PM
swank's Avatar
more talk here as well.
http://1stgen.org/viewtopic.php?t=385
Old Feb 12, 2007 | 04:47 AM
kennedy's Avatar
Originally Posted by swank
To answer your question on that forum:
Yes, it is ok to weld on axle tubes. just take all the weight off of the axle. As in have it removed and sitting on a table or jack stands. You can tack weld stuff with it in place. That and be conscience of the location of inner seals and such, you don't really want to be welding with in a few inches of seals, unless you plan on replacing them.
Old Feb 12, 2007 | 05:32 AM
KartRacer's Avatar
Here is a place that may have some of what you need. I know it is lowrider stuff, but they do have a good bag assortment, and who knows, maybe one of their 4 link kits is heavy enough.
http://www.suicidedoors.com/
-Steve
Old Feb 12, 2007 | 10:21 AM
Fergavs's Avatar
I've done a few bag set-ups. I assume this is on a 4X4. I have only done 2wd however lots of info is out there for both. A great read and well worth adding to ones collection is a text called Chassis Engineering by Herb Adams available here:
http://www.amazon.com/Chassis-Engine...e=UTF8&s=books
I have or had a step by step guide to doing a full front and rear 4-link suspension. It has angles needed and info about steering geometry. I'll try to find it and let you know.
Old Feb 12, 2007 | 10:29 AM
swank's Avatar
sweet! thanks a million. i'd love to have a look.
Old Feb 12, 2007 | 10:30 AM
1stGen545's Avatar
I am going to put an air ride on my 96 by removing the springs and replacing them with 2 pieces of 4" Chanel welded to make a box 4"x3". Putting a spring bushing in one end mount it where the front of the spring went and to the axle then make it drop down to axle hight behind the axle and then turn straight back and make a mount for the bag. Will also have to have a large pan hard bar. It is the same as a Peterbuilt air spring set up. I did some looking and found that Air Lift sells a kit just like the one I am going to build but it is only for 3rd gen trucks look under Past Projects for the Road Tamer. Guess I'm not the only one that had the same thought. I will use a set of KW bags I found for better load handling and better ride. With the small bags most makers suggest using air tanks for expansion tank to make it ride smother.
Old Feb 12, 2007 | 10:37 AM
Fergavs's Avatar
Not the info I mentioned or for our year truck but worth a read:
http://www.fourwheeler.com/techartic...ag_suspension/
Old Feb 12, 2007 | 01:21 PM
DennyT's Avatar
Heres a link to what I widdled out. It works good.
https://www.dieseltruckresource.com/...nt+spring+lift
Old Feb 12, 2007 | 02:17 PM
andyr354's Avatar
If it is highway only and you don't need articulation for offroad a two link with a panhard will work fine.
If you need beter flex look into a 3 or 4 link setup.
On pirate4x4.com forums you can search for an excel spreadsheet for calculating all the aspects of a 4 or 3 link system.
herb
Jul 18, 2008 08:25 AM
Rushford
23
Aug 26, 2007 07:21 PM
Deezle98
May 11, 2006 01:17 PM
12valve@heart
Jan 27, 2004 01:25 AM
Luke S
Mar 24, 2003 06:59 AM
