Those that have painted your trucks?
Old Sep 27, 2014 | 03:47 PM
TJE's Avatar
TJE
What type filters did you use? I don't want to spend a ton of money just something that will do the job!
Thanks, Tony
Old Sep 27, 2014 | 04:06 PM
APD's Avatar
APD
Air line filters?
Paint gun filters?
Paint strainers?
Spray booth filters?
There are lots of filters involved in painting.
if you mean the filters used on the air line before the gun, they sell disposable ones wherever you get your paint.
Old Sep 27, 2014 | 05:47 PM
TJE's Avatar
TJE
I just want something to paint the truck with....without spending more than I have too.
Old Sep 28, 2014 | 02:12 AM
rrgrassi's Avatar
Are you talking about FILLERS (Like Bondo) Or FILTERS?
Old Sep 28, 2014 | 07:14 AM
Thanks, Tony
Describing the"job" you want to get done, will help us understand what your up to.
THEN we might be able to help.
Otherwise, CHEAP paint jobs can be done with a paint brush…like my '80 W250 gasser plow truck, hand painted in "Richard Petty" blue.
Old Sep 28, 2014 | 09:33 AM
TJE's Avatar
TJE
FILTERS! i just want to take it back to stock. They way it looked new
Old Sep 28, 2014 | 10:57 AM
fatt's Avatar
A filter for what? I'm so lost.
Old Sep 28, 2014 | 02:13 PM
APD's Avatar
APD
I usually use paint to paint trucks.
I was really trying to help, but you're not giving us any info.
Go to youtube and there are a million DIY car painting videos.
Old Sep 28, 2014 | 06:09 PM
Painting with FILTERS is more expensive then using paint brushes.
The filters wear out quickly, leave streaks and they don't hold much paint.
Old Sep 28, 2014 | 09:44 PM
TJE's Avatar
TJE
Ok I apologize.... I just re read my op. What are some adequate "air" filters....to filter out the water from the air compressor?
Old Sep 29, 2014 | 10:01 AM
patdaly's Avatar
K, that's better, it will depend on where you live.
Many locations, especially in the colder months will do just fine with a disposable inline air filter at the gun.
For most areas, a 2 stage filter upstream is the minimum I would run, I built my own, but here are a couple of places I buy from.......
http://www.smartshoppersinc.com/Spra...cessories.html
http://search.eastwood.com/search?w=air%20filter
It really doesn't make sense to spend 400 bucks if you are only going to paint 1 vehicle, but say the $ 79.99 Eastwood single unit plus the disposable at the gun wouldn't hurt at all.
http://www.eastwood.com/ew-oil-coale...n-1-2-npt.html
Old Oct 1, 2014 | 08:26 AM
1STGENFARMBOY's Avatar
I have a small 5 gal tank about 2 feet away from my big tank with the air plumbed into it with another water drain on the bottom of it, as a second gravity drain and I use a new one of those little plastic things in the link above when I paint.
If you keep them drained and your compressor is pulling warm air from the room it won't make as much water as pulling cold air from outside.
I only have water if I forget to drain the tanks for a long while.
Old Oct 1, 2014 | 09:07 AM
mknittle's Avatar
same here.
Old Oct 1, 2014 | 12:12 PM
Nughuffer's Avatar
I used about 10-11' of leftover ⅝" cooper line to make a cheap dryer/condenser.
I rolled the line around a 5gal bucket to create a coil, connected the upper ⅝" inlet of the coil directly to the pump head outlet then ran the lower ⅝" outlet of the coil through an air/water separator, then to the tank. It lowers the compressed air temp drastically and removes 90% of the water before it hits the tank. I also run an additional air/water separator between the regulator & the airline quick connect in addition to the manual tank drain just to be sure. So far its worked well and only cost involved was buying the fittings/adapters between the ⅜" & ⅝" line.
A lot of folks will use an old automotive evap or condenser core as well. I didn't have one though.
Maverick2001
Mar 20, 2014 09:48 AM
TrkEnvy
Apr 24, 2009 05:06 PM
trik396
Feb 11, 2006 09:02 PM
trik396
13
May 1, 2004 12:58 AM
soundbrz
Nov 19, 2002 11:36 PM
