Thermostat question
Old Dec 5, 2010 | 02:10 PM
GIT-R-DONE's Avatar
Thermostat question
For our trucks, did they make different temperature thermostats.
I cant get mine to heat up, (dont know what is in it) and was wondering if they made like 180-200 thermostats?
What is stock temp? TIA
Old Dec 5, 2010 | 02:38 PM
Stock is 180 degrees. You can get a 190.
Old Dec 5, 2010 | 04:28 PM
cseby's Avatar
after a lot of no heat problems i put a cummins thermostat#3802968 in my 1989.don't forget if you have an early 89 the head needs the water passage enlarged.i also had no heat problems in my 1990. put the cummins thermostat in it and also did the trick.they hit me $38.88 a peice.i think that is quite expensive.the only difference i can see from others are two rattle pins.all i know is they solved my problem.also i found when you first start the cold truck make sure the steel line running over the thermostat housing from the head heats up fairly quick.then you know your thermostat is working correctly and you have no blockage there.
Old Dec 5, 2010 | 06:30 PM
GIT-R-DONE's Avatar
Thanks for the info. I have my radiator blocked with cardboaed, and even at that, it barely goes over the first line in the gauge. I know the gauge works....will have to do something pretty soon.
Old Dec 5, 2010 | 07:20 PM
artieb's Avatar
Hi, now that the cold weather is upon us, I too need more heat. I wonder what "precision" thermostats would fit?
Old Dec 5, 2010 | 08:16 PM
1992gen1_fan's Avatar
Mine used to not heat up, so i installed a 190* i believe and i can keep my windows down half way when its 20* out and be comfortable. So in other words it improved mine 100%.
Old Dec 5, 2010 | 09:15 PM
befitz's Avatar
Autozone sells a 180 thermostat for about $18, and a 192 for about $14.
Both are Failsafe, the ones that can't fail closed. That is the one for a '90
Dodge Cummins.
Old Dec 5, 2010 | 10:11 PM
lovin1stgens's Avatar
id get a thermostat out for a second gen 24v. its bigger, but also hotter. from my experiences you'll have to shave down the outer ring/flange doohicky to get it to fit in the housing, but after that it will work just fine. i took the housing off mine so i wouldnt have to make a million trips from the grinder to the truck lol
Old Dec 6, 2010 | 04:25 PM
firstgen250's Avatar
hey there. the easy fix i found is the cummins thermo...its more money but less bull..
Old Dec 7, 2010 | 01:25 PM
lmullen's Avatar
My original thermo quit at 71k,
Took two tries to get a good one.
Second one worked great.
Old Dec 7, 2010 | 02:38 PM
DPFservice's Avatar
I installed a napa 180* for $7.99 and the temp gauge fluctuated the whole time. I switched to a geniune Cummins 180* for the $40 and now have steady open/close. Worth the money! Goes to show you get what you pay for.
Old Dec 7, 2010 | 04:31 PM
GIT-R-DONE's Avatar
I found one today that is a 195*. I doubled checked with the parts guy and he said it was for my diesel.
This is a different install than my 90 was..(.install sideways..maybe?)..but wont have time to put it in till first of next week.
Old Dec 7, 2010 | 05:16 PM
cseby's Avatar
don't forget to put the rattle pins at 6:00 and 12:00.seems to make a difference.
Bookshelf
May 30, 2009 01:17 AM
laker
Feb 4, 2006 02:49 PM
Truck96
Dec 22, 2004 05:55 PM
Truck96
Nov 14, 2004 09:47 PM
blackboat
Jan 22, 2004 09:53 PM
