Talking about an AFC delete!! (pics)
Old Apr 15, 2010 | 05:00 PM
  #46
schamran's Avatar
Wow. I can't imagine what a billet VE must cost!? I bet it breaks records though.
Old Apr 15, 2010 | 05:49 PM
  #47
sdseva's Avatar
get the hint yet
Old Apr 15, 2010 | 06:13 PM
  #48
Originally Posted by unixcowboy
Well, I'm connecting an electric that will push 60psi ...That should give some advance.
Wonder if a CNC'd pump could hold that pressure ?
Not much. If you drop below about 100 psi you start losing advance.
The stock piston only gives 9 degrees, so you still need to run a good bit of base timing for max HP.
Old Apr 15, 2010 | 06:15 PM
  #49
dieselJon's Avatar
Maybe a billet steel bottom might work...
Old Apr 30, 2010 | 11:53 AM
  #50
unixcowboy's Avatar
You know - sometimes Begle1 is really off the wall...
But in this post :
http://1stgen.org/viewtopic.php?f=4&t=8070
He may be onto something...
Check the 9th post where he describes what he's planning...
AND PLEASE don't too loud.
With Denny's billet case being fed by that monster - or something close - he may be onto something
Old Apr 30, 2010 | 01:43 PM
  #51
schamran's Avatar
Way over my head.
Old Apr 30, 2010 | 08:09 PM
  #52
Originally Posted by schamran
Way over my head.
He wants to feed his injection pump on his truck WITH a BIG injection pump off a semi....if that makes sense.
Old Apr 30, 2010 | 08:58 PM
  #53
apwatson50's Avatar
The problem with holding lots of pressure isn't the case itself, or the seal coming out of the case. At a certain point fuel starts leaking past the seal on the shaft. So if you feed the case with lots of pressure, you need some sort of double seal or just some way of keeping all that pressure off of the shaft seal.
Old May 1, 2010 | 09:34 AM
  #54
unixcowboy's Avatar
Agreed on the shaft seal..
What Begle1 is talking about is bypassing the case and feeding the H&R directly by going into the shutoff solenoid hole.
The vane pump sucks fuel from the low pressure case and feeds it into the H&R at high pressure. The H&R then compresses it more and feeds the injectors.
One less step - feeding low pressure fuel into a case that will leak when you increase fuel pump pressure past a certain point - should mean one less point of failure.
My concern is advancing the injection timing at higher rpm's. Since you'll be bypassing all the normal timing components - governor, vane pump, etc. - it seems the timing will be static.
Old Nov 26, 2010 | 08:53 PM
  #55
Moparbubba's Avatar
denny t how smokey is it? ive never run with out a fuel pin or afc and are you gona make em to sell? i heard you where gettin a new cnc machine. i like the pin of yours i got.
Old Nov 30, 2010 | 12:12 PM
  #56
unixcowboy's Avatar
Denny ---
Any progress on this ????
darrenG
Aug 9, 2005 10:22 PM
royta
Feb 15, 2005 10:15 PM
Mexstan
Dec 1, 2004 08:29 PM
BIG&BAD
Feb 20, 2003 03:47 PM
