Tail Gate latch
Old Jun 6, 2021 | 11:47 AM
91.5CTDBanks's Avatar
Tail Gate latch
Both of the plastic shims have busted off the tail gate latch rods. I have the LE with the tail gate trim panel. Will I have to pull the panel to get the latch out enough to replace the shims?
Thank you,
Old Jun 7, 2021 | 05:02 AM
KRB's Avatar
KRB
I didn't. But there could be an easier way...
Old Jun 7, 2021 | 07:09 AM
Well. There is a part of the trim that goes up into the latch handle recess. I have watched a video of the procedure and it is easy but the tail gate in the video did not have the trim panel.
Old Jun 7, 2021 | 10:38 AM
jungpeter's Avatar
5 Year Member
I'm assuming by "shims" you are referring to the plastic clips that hold the tailgate linkage rods in place in both the latch assemblies and the handle assembly? My LE also has the tailgate trim panel. Removal is easy-peasy, with eight screws on the inside of the tailgate, and four plastic push pins in the corners. GENTLY pry the plastic pins loose. Breaking one may be difficult to replace. Once the trim panel is removed, the tailgate handle assembly in the center of the tailgate is easily accessible for replacement of the plastic clips that hold the control rods. And on the LE, unless the trim panel is removed first, it is IMPOSSIBLE to work on the tailgate latching assemblies. The clips and linkage rods are simply inaccessible.
Old Jun 8, 2021 | 10:55 AM
Great. I will get to it. Thanks.
Old Jun 13, 2021 | 07:53 AM
maybe368's Avatar
Just a comment. My LE tailgate has not been openable for twenty years or so using the center handle. I have considered fixing it but I always come to the conclusion that having to raise the little arm coming out of the latch in the passenger side is well worth the fact that not any fool can walk up and open the tailgate. Just a thought 🤔…Mark
Old Jun 13, 2021 | 08:15 AM
Almost all my 1st and 2nd gens need to have that little arm inside the bed lifted to make the tailgate open. I am with Mark. I just look at it as an anti theft device for my tailgate.
Old Jun 14, 2021 | 11:18 AM
jungpeter's Avatar
5 Year Member
Or, if you're like me and simply want to restore the truck to OEM functionality, you'll simply remove the trim, unbolt the center latch to ease removal of the latch arms, and simply replace the offending latches with new. https://www.carparts.com/details/Dod...T-RB38671.html
Regards,
Pete
Old Jun 16, 2021 | 05:13 AM
KRB's Avatar
KRB
It's kind like the the old farmer in a Wendell Berry book. When he's asked why he doesn't patch his leaky roof, the farmer responds: when it rains he can't and when it don't it doesn't need it...
Tallguy67
Jan 17, 2014 10:21 PM
1bad93
Apr 10, 2010 07:42 PM
Mike T.
May 14, 2007 10:19 AM
OR4ster
May 23, 2006 09:13 AM
NoSparkplugs
Sep 30, 2005 03:13 PM
