dang tail gate wont open!
well i went to get a crate of soda last week and the dang tail gate wouldnt open. i had to use them little clips on each side of the tail gate. how do i fix this? and is this a common problem cause i had a 92 gasser that did the same thing?
I believe there is a write up in the sticky.... Cost you like, $5. I need to do it too.
Tailgate latch repair:
http://ramchargercentral.com/index.p...owtoshow;id=29
There ya go...
There ya go...
Mine was just rusted on my 92. Took me an hour or so of PB Blaster and wiggle to get it freed up. I had to take out the whole assembly to get it to work. The guy I got it from had a bungee cord holding it shut.
Yea a pain. The little rods inside the tailgate just needs some TLC and a few bad words because they are a pain to work on. But the end result is a smooth working unit. Have fun and good luck with it.
Often the metal pieces on the latch on each side need tweaked back straight where the actuator rod hooks into them. You'll get it fixed once you get it apart, not a hard deal once you do a few of them.
YUP, Mine were bent also and its easy to spot it when its all apart. They bend and then there is not enough movement to pop the latch.
thanks man
