Tach for an 89?
Old Oct 3, 2006 | 05:31 AM
pred's Avatar
Tach for an 89?
I have seen many tach's that run off of an injector line, and then i have seen some that run off of a probe strapped to the alternator, I dont have expirence with eather type,,,
The one for the alt is a autometer, and the injection line, well all those seem to be a digital read out, And i done really want one of them,,
Is anyone here running one of the two types mentioned here???
Please, any imput would be appreciated!
Peter.
Old Oct 3, 2006 | 05:57 AM
Begle1's Avatar
I have an alternator tach; works like a charm. (It also double as an electric-intererence detector when the engine is off and it picks up the blinker pulses...)
Old Oct 3, 2006 | 02:39 PM
pred's Avatar
Begle1,,, How does it know the engine rpm? dont alternators spin at different speeds on different applications??? Auto meter, says it is a install and play, No adjustments, I just dont see how with different automakers spinning the alt at different speeds,,,per engine rpm..
Am i missing something?
Peter
Old Oct 3, 2006 | 03:07 PM
I have the AutoMeter alt. tach. You have to calibrate it to engine RPM. I don't know where it says that particular tach is "plug & play", obviously that is bad info.
If you know somebody with an optical tach, you can calibrate it that way. Or just run your tire size and gear ratio through one of the many online calculators and calibrate it on the road.
Old Oct 4, 2006 | 09:04 PM
pred's Avatar
Where might i find one of these online caculators?? I have a small hand held gps to get my speed just right, speedo bounces just a bit.
Thank you,,,
Peter.
Old Oct 5, 2006 | 06:27 PM
This is the first one that popped up on a Google search. There are a zillion of them.
http://www.et-studios.com/motorsports/gears/gears.html
danlit
Mar 20, 2003 06:29 PM
poolboy
Dec 18, 2002 08:00 AM
cuminzd
Nov 13, 2002 01:56 AM
1stGenBikeHauler
Nov 1, 2002 10:27 AM
hellotbone
Oct 11, 2002 04:04 PM
