Any used AutoMeter Diesel Tach??
Old Oct 27, 2002 | 11:58 AM
1stGenBikeHauler's Avatar
<br>Has anybody used the AutoMeter Diesel tach on their<br>first Gen truck? I am asking becaues I am not sure<br>how it triggers and if it works with the OE crank position <br>sensor. The one I am looking at is PN 2888 and its on the <br>AutoMeter website. <br><br>I have also looked into the Isspro gauges but they seem<br>a bit spendy.<br><br>Thanks for any info.<br>Matt<br>
Old Oct 27, 2002 | 12:08 PM
Monty's Avatar
Re:Any used AutoMeter Diesel Tach??
Im glad this discussion came up. I have the Isspro Tach on mine along with the kit that hooks up to the existing CPS harness. Well, 2 days ago the tach took a . Ive checked all of my connections, everything!. Still no go. 8 months of use and it dies. &gt; <br><br>I will look around and see about the autometer tach. As I will prolly have to get another brand if the supplier will not warrantee this one.
Old Oct 27, 2002 | 02:29 PM
Monty's Avatar
FWIW...if your looking for a cheaper alternative. Tiny Tach makes a tachometer for around 65 bucks. Alot of the 1st gen guys on the TDR say it works great. A little slower reaction than an analog gauge, but all in all it works great. It recieves its signal off of one of the injector lines. It contains an hour meter, two service timers, and max RPM as well. The only downfall is that it has no light.<br><br>Tiny Tach
Old Oct 28, 2002 | 03:49 PM
ZONE5AB's Avatar
I have an Autometer 2888 on my rig and it works great but it it's not a bolt on. The sender is held on the alternator with a giant worm gear clamp and the tach has to be calibrated to match the signal from the sender. Fortunately, I have an optical tachometer so the calibration (adjustment screw in the tach head) was a cinch but for those without access to one, there is the extra expense/hassle of having it calibrated.<br>If I had known about the Tiny Tach at the time, I might have chosen it.
Old Oct 29, 2002 | 11:46 PM
<br>Thanks for the replies Okie and Zone. Thats the<br>info I was looking for. I was not sure how the Autometer tach got its trigger...I supose its some hall effect with the<br>alternators field....and it needs calibration. Ok Its all<br>clear now.<br><br>
Old Nov 1, 2002 | 10:27 AM
haloman's Avatar
Has anyone used the Tiny Tach? It appears to be pretty good. Any help is greatly appreciated. Thanx
deanhinsley1963
May 16, 2011 04:53 PM
440FURY
Jul 19, 2004 10:55 AM
jiMMyCTD
Jun 26, 2004 06:27 PM
Evildiesel
Aug 7, 2003 08:44 PM
country
Jan 28, 2003 08:15 PM
