Little tach problem
Old Oct 7, 2002 | 06:39 AM
hellotbone's Avatar
Little tach problem
Hey guys I just noticed this the other day on my truck. When Idling the tach bounses up and down about 1/8&quot;. Is that normal for these trucks mine is brand new got less then 22,000 KM/h On it. it also does it when in cruise.<br><br>Jamie
Old Oct 7, 2002 | 01:08 PM
Superduty12v's Avatar
Muted User
Re:Little tach problem
I haven't traced the problem yet but my tach will completely stop working for a few minutes than start working again and be working perfect. No jumping or anything. Then it'll half *** work.. then die. etc
Old Oct 7, 2002 | 02:01 PM
CMN_NOT_STROKN's Avatar
Jamie,<br>The movement of the tach is normal. It has probably done it since you bought the truck and just never noticed in before. It has to do with the ecm reading the crankshaft position sensor and updating the tach. I think that everyone's truck does it to some extent. I wouldn't worry about it.
Old Oct 7, 2002 | 08:26 PM
GSchlegel's Avatar
Maybe its a over-valved problem. The electrons getting confused! My properly-valved 96's tach is nice and smoooooooth.<br><br>Gene
Old Oct 7, 2002 | 08:45 PM
phox_mulder's Avatar
You are correct sir.<br><br>The tach is electronic and gets its info from a sensor.<br><br>The electrons are getting confused.<br><br>Poor PCM or ECM (whichever controlls it) is overwhelmed with information and can't keep up with everything in a timely fashion, so the Tach jumps around as it gets info a little late.<br><br>My 2002 has done it from day one.<br><br>If not for this board, I would have worried a bit about it as well, still did anyway.<br><br>phox
Old Oct 7, 2002 | 09:11 PM
chuck3's Avatar
Yeah its a PROPERLY VALVED thing.
Old Oct 11, 2002 | 01:03 PM
ridofpwrstroke's Avatar
IF THIS DOES HAPPEN TO OUR TACH'S RIGHT NOW, WILL IT EVENTUALLY GO BAD LIKE YOURS? I WONDER IF DODGE WILL REPLACE NOW? AND WILL THE PROBLEM GO AWAY? MY TACH JUMPS ALL THE TIME.
Old Oct 11, 2002 | 02:20 PM
AlpineRAM's Avatar
It depends on how high the tach jumps. If it's just about half way between the marks its normal. The electronic tach just has this many positions. If rpm falls a little (something like 1-10 rpm) when the tach was on the low end of the segment you'll see a jump. <br>If it fails completely for some seconds or so I'd suggest to check the cluster (Self test depending on model year) and look for bad connections. Sometimes a bit of contact cleaner and dielectric grease goes a long way<br><br>HTH<br><br>AlpineRAM
Old Oct 11, 2002 | 04:04 PM
IT DOESNT STOP. THE TACH JUST BOUNCES. WASNT SURE. AFTER READING SOME POSTS IT LOOKS NORMAL.
thenrie
Jul 23, 2010 11:10 PM
Mexstan
Sep 16, 2006 05:29 PM
JW3
Mar 15, 2006 08:23 PM
