symptoms of a dana 70 on it's way out?
well i had shuddering at each shift in my truck, the truck would stuggle up hills, there was a wierd vibration all the time, now i remove the rear driveshaft and drive it in 4 wheel, and the truck has no shudder at each shift and rides like a dream, with no vibration and pulls up hills great. is my rear end on it's way out?
Thats what the old mans was doin
pulled the cover and it had about an 1/8" of side to side play, it was missin three pinion teeth and the tone ring was fubar. The truck now has a D80
IMO the 70 is a weak rear
distorted rubber in the u joints, and if you can see where the cap has been turning in the yoke, its a bad u joint, rust is another factor, i had 2 broken needle bearings in my u joint and it felt like i had new tires w/o balancing
When my rearend went out it had a slight shudder to it but a constant light vibration. I pulled the inspection cover but didn't see anything but I didn't turn it. A day or two later I was crossing a bridge with concrete walls on it and I heard a roar that I haven't heard prior to that, the concrete walls created an echo chamber affect. After I got off the bridge the roar went away, turned around and rolled the windows down and repeated the process loud roar. Went home jacked her up and pulled the inspection cover, nothing till I rolled the carrier, two teeth on the ring gear and one full tooth and two big chips on the pinion. Good luck on it!
Dinero10
58
Jan 30, 2017 06:41 AM
MadFrog
Jan 24, 2006 11:06 AM
