Stuck in 5th Gear
5th gear
I dont think the trans needs to come out i helped glhs repair his at the strip take your shifter and tower plate out look in there you will see two u shaped metal forks get a a big flat blade screw driver and push each one back and forth till you get them free then make it so they are together and they make almost like a square you should be good to go from there be sure to start it to make sure its out of gear then reasamble.
dont know alot about trannies but this happened to my friends jeep- it was his throwout bearing, don't know what that really is but that was his problem he couldn't get it out of fourth
hope that helps, my two cents
Justin
Justin
Yeah, worst case scenario, you need to buy shifter forks, or have one machined if one is broken. One broke on my truck. Just had it welded and machined. It was done in a day. If anything, it will significantly decrease the value of the truck, and you should be able to pick it up pretty cheap. Only problem is u wont be able to drive it.
I bet the 5th-reverse shift lug has the corner broken off. It lets the shifter fall back to neutral, while the trans is in 5th. There could be other problems inside the trans. Pop the shifter out and you will know.
birdboy
Dec 12, 2018 09:02 PM
LemonDodge
Sep 16, 2010 07:33 AM
