Is the stock crankcase ventilation enough?
Old 02-28-2009 | 08:48 PM
1985cucv's Avatar
Guys i was wondering if the stock crankcase ventilation is enough? i know there is a thread on here about added ventilation but is it really necessary? thanks
Old 02-28-2009 | 10:33 PM
sdstriper's Avatar
Stock is enough and if you look into this you'll find that many high HP guys have done nothing extra...
Old 03-01-2009 | 07:07 AM
Stock is enough until the engine gets tired or you have a vacuum leak.
Old 03-01-2009 | 06:45 PM
mhuppertz's Avatar
Or you are way up on boost. I had to put an extra vent in, but I have a high mileage engine with a vacuum leak!
Old 03-01-2009 | 08:27 PM
1985cucv's Avatar
i have like 35 psi of boost
Old 03-01-2009 | 09:41 PM
whereswaldo250's Avatar
How do you know when you have a vacuum leak? I don't know for some reason...
Old 03-02-2009 | 12:09 AM
GasganoFJ60's Avatar
HERE is BC's writeup on adding extra crankcase vents.
Old 03-02-2009 | 04:28 PM
BC847's Avatar
1st Generation Admin
You may need additional venting if you keep having oil blow past known good engine seals along with the under-side/driver's side of the cab being wet with oil (from the single OEM vent).
Old 03-02-2009 | 04:40 PM
mhuppertz's Avatar
I blew out the rear main, but I think a leaky vacuum pump had a lot to do with it!
fade94
08-20-2010 04:20 AM
1985cucv
03-26-2009 07:19 PM
DMcPherson
02-03-2009 10:20 PM
Boatnik
08-05-2007 09:09 PM
danimal 95
32
02-15-2004 07:23 PM
Quick Reply: Is the stock crankcase ventilation enough?
