Stock boost numbers?
Old Sep 14, 2006 | 06:22 PM
MiniC's Avatar
Did a search mine seems low. The truck, 1992 3/4 ton, 216,000 miles, auto tranny, completely stock other then a straight pipe. Installed a boost, pyro, tranny temp gauge. The EGT's are no higher then 900 degrees wot. The boost is only hitting a max of 14psi. I have not checked the ductwork for holes yet. I wanted to verify that this is a low number. What do you guys think?
Old Sep 14, 2006 | 06:25 PM
That's a great number for a stock '92. They run 12 - 14 psi.
Old Sep 14, 2006 | 06:26 PM
flashgordon's Avatar
I would say that 14 is good........checking hoses and intecooler wouldn't be a bad idea, but like i said before 14 would be in the normal range.
Old Sep 14, 2006 | 06:41 PM
MiniC's Avatar
I looked over the boots/connections everything looked real good but that doesnt mean anything. I will do a pressure check here one of these days. Good to here about the boost numbers!! Thanks for the help guys!
Old Sep 14, 2006 | 06:51 PM
Begle1's Avatar
Why do they run so low?
I thought my 18 PSI was bad?
Old Sep 14, 2006 | 07:03 PM
G1625S's Avatar
Remember, a '92 has the lag-pig 21cm housing. Add the itty-bityy i/c injectors, a stock pump and an automatic that won't load the engine very hard and 14psi is about all that can be expected
Old Jan 22, 2007 | 03:49 PM
4RnrRick's Avatar
Bringing this back from the dead....
I just got gauges and here are some base line numbers I got today running the truck hard.
'92, w250, 33" BFG AT, A518, 21cm housing (ugh)
Mods - BONE STOCK, 280K+
Load - Empty
Throttle - WOT
Pyro - 1080 F slightly uphill (1020 F on flat ground)
Boost - 15.5 psi
Tranny temp - 180 F
Ambient Air - 45 F
So I guess its pretty much inline with what you other guess are getting. I was concerned that it might be a bit low.
Old Jan 22, 2007 | 04:41 PM
TexasHardcore's Avatar
My old '92 bone stock H1C/21cm with only a BHAF and straightpiped stock exhaust was seeing 20psi. With each upgrade came more boost until I reached 46psi with only an HX35/40 Hybrid-16cm2, 4" straight pipe & downpipe, POD's, fuel pin & pump tweaks.
Old Jan 22, 2007 | 05:23 PM
Ace's Avatar
Ace
I initially saw 14 max, stock. Now see 30 max. No idea where that came from. Looks like a small twist of the full power screw, 366 pring, intake and exhaust did alot for me.
Old Jan 22, 2007 | 06:12 PM
91.5CTDBanks's Avatar
I am getting 15 psi and about 900* egt's. If I catch it just right my truck will actually get up and go.
Old Jan 22, 2007 | 07:01 PM
Micaiahfied's Avatar
4RnrRick, those numbers are good for a stock truck. my 92 D250 auto only hit 13 til i started messing with stuff.
Old Jan 22, 2007 | 10:16 PM
GLHS's Avatar
My stock 92 was at 14 @ 6000' before I started messing with it. Non-intercooled trucks should be around 21 stock. They had bigger injectors, 18.5 housing and without the intercooler would make more boost due to the hot intake charge. I once bypassed my intercooler with a pipe and boost went up 3 psi but truck made a lot more smoke and had noticebly less power.
Old Jan 23, 2007 | 12:50 AM
Jim Lane's Avatar
My truck would get 25 PSI before I did anything to the pump and I thought that was bad.
But it could be the Ram Air helping.
Jim
lessismore
Nov 12, 2010 08:50 AM
gellibee
Mar 26, 2009 03:57 PM
CaptainKelley
Nov 12, 2008 05:42 PM
sCreamin400
Nov 2, 2008 01:46 PM
Gotlift01
Aug 28, 2005 06:01 PM
