Comp boost numbers on stock turbo
Old Aug 26, 2005 | 06:01 PM
Gotlift01's Avatar
Hey guys, I noticed that with my comp ( wire taped ) I am only getting around 20 psi of boost WOT. Sometimes it will get to 22 if I really lay into it driving around. I know the stock HY35's aren't good for much more, but I was curious if ya'll think my boost is a little low?? My egt's also heat up pretty **** quick and I can hit 1350* but haven't let it go any farther. I was thinking about trying to screw around with my wastegate to see what the results are..........or am I wasting my time with this turbo???
This winter I am planning on a bigger turbo and some injectors, but for now I would like to get a little more out of the stocker if possible. She runs GREAT as it is, but could it run even better? I know boost isn't always the answer for more power, but from what I have been reading on here, most of you guys with a similar set up as mine are pushing way more boost. Let me know what ya think!!!
Thanks guys
Old Aug 26, 2005 | 06:12 PM
Marine's Avatar
Veteran: Marine Corp
With my setup (EZ) and the wastegate spring, I get 31#.
I'll know tomorrow what I get with the Comp.
Mike
Old Aug 26, 2005 | 06:15 PM
CTD NUT's Avatar
That is quite low for a Comp on 5x5.....with stock injectors I could easily hit 35 psi - and that is with a HX35.......you elevation could have something to do with it but it still seems low.......did you install the boost elbow supplied with the Comp?
Old Aug 26, 2005 | 08:11 PM
graphitecumnz's Avatar
no boost elbow on HY-35's...
more appropriate question is whether or not you modified the wastegate(J-hook)?
I could easily hit over 30 psi with just the EZ...
Old Aug 26, 2005 | 10:10 PM
BigBlue's Avatar
I get 36 out of mine right now. I've seen 40psi out of mine with 0 fp and stock injectors.
Old Aug 27, 2005 | 01:50 AM
ramtd02's Avatar
if i disconnect the boost controller on mine.....i can see 42 psi ......i didnt let it go any further...the hy35 does not sound healthy above 38 psi.
Old Aug 27, 2005 | 09:36 PM
Gene007's Avatar
I have a turbo master on my stock turbo. Set for 28 - 30 psi, but it will peg my 35 psi gauge in a heart beat.
Gene
Old Aug 27, 2005 | 11:10 PM
2 busy's Avatar
I can get only 26psi with my comp/ wire tapped. I have tried everything short of plugging the wastegate hose. I seem to have plenty of power with the comp I'm almost convinced it is a bad gauge.
I have pressure tested and can not find any reason why i have so low boost.
Go figure.
Old Aug 28, 2005 | 06:01 PM
CODODGE2500MAN's Avatar
WELCOME TO COLORADO
That's all you get up here w/ the elevation. I get about 28 max, usually 26. You wanna see higher numbers, get out of colorado. Enjoy
CaptainKelley
Nov 12, 2008 05:42 PM
sCreamin400
Nov 2, 2008 01:46 PM
MiniC
Jan 23, 2007 12:50 AM
dodgediesel
14
Dec 14, 2006 09:54 AM
joefarmer
20
Dec 11, 2004 05:25 AM
