Steering Binding
Old Oct 16, 2004 | 04:50 PM
Stickboy's Avatar
Steering Binding
Hi there,
new to the forum and wondered if you all might help me out here. I've done a search for this problem and I couldn't find the exact problem anywhere.
Anyway, The problem is:
When turning slightly left it feels like linkage is binding and with a little more turning left it'll suddenly release and oversteer. Sort of feels like a bearing is in a pit and when you turn the bearing jumps out of the pit and turns dramatically. I originally thought that a ball joint was binding but it doesn't seem like it would be a ball joint since it only does this to the left. Reading more the drag link comes up and then reading even more the u-joints come up.
It doesn't do this turning to the right and it doesn't do it if you are going slow and make a left turn. More when you are taking mild corners or changing lanes (slight left turns).
I'd hate to start sinking money/time into this replacing parts that might not need replacing.
thanks for the help...
oh, this is a 92 d250 diesel.
-mike
Old Oct 16, 2004 | 06:05 PM
Drag link and U-joints are out, you have a 2wd. It sounds to me like a steering box problem. Does it feel the same with the front tires off the ground?
Old Oct 16, 2004 | 09:13 PM
Rammer64's Avatar
Same as mine But different
I have the same problem but mine is hard to the right.
Check out the third post.
https://www.dieseltruckresource.com/...threadid=52727
A friend of mine at the alignment shop said it's in the steering box control valve for the hydraulics part of the pump. He says the individual seals/parts can't be bought for just the spool valve. He checked out the book for the box (DIESEL DIFFERENT THAN GAS) and a rebuilt box is over $800 Canadian.
Old Oct 16, 2004 | 09:24 PM
Tommy93w350's Avatar
Steering box timing is off or worn old fluid. The first thing I would try is changing the fluid out of the pump. Use a suction type manual pump, suck out all the fluid, fill with new synthetic fluid, drive it, come back and repeat steps a few times.
This the simplest do-it-yourself fix before you send it to a garage$$$$$$.
Old Oct 17, 2004 | 09:55 AM
Stickboy's Avatar
thanks for the suggestions,
i don't know if this makes a difference but this is a 4wd d250.
so are u-joints/drag link still a potential?
mike
Old Oct 17, 2004 | 10:10 AM
If it's a 4wd it's a W250 not a D250 , and yes, the U-joints and drag link can be problems with 4x4's.
Old Oct 17, 2004 | 10:49 AM
Stickboy's Avatar
oops, i totally brain farted on the model number... yes w250. i've been shopping for a d250 this past week and maybe that is on my mind....
do you think the fluid could be an issue still or should i spend my efforts on linkage?
-mike
Old Oct 17, 2004 | 04:40 PM
Couldn't hurt to change the fluid. Jack up the front axle and see if you have the binding with the wheels in the air. It does sound like a box problem to me.
Old Oct 17, 2004 | 09:54 PM
bigredbrick's Avatar
Mike,
The front axle u-joints aren't hard to check. Just jack up the front and support it with jack stands, make sure the steering column is unlocked, rotate the u-joint so it lines up with the ball joints ( + not X, if that makes sense ) and grab hold of the tire and try turning/steering it. Rotate the axle u-joint 90 degrees and try it again.
I've had a few 4x4s but never had the u-joints freeze up til my 93.
It creates some strange steering problems.
Chris
Old Oct 17, 2004 | 11:16 PM
Stickboy's Avatar
chris,
thanks, i'll try these things tomorrow night. had to finish up and winterize the diesel landcruiser tonight.
-mike
Old Oct 18, 2004 | 12:44 AM
moTthediesel's Avatar
Hey mike,
What kind of LandCruiser do you have?
I'm lurking this site because I'm shopping for a 1st Gen CTD truck, but my daily driver is a '82 FJ60 with a Canadian market 3B diesel implant. I'm running mine with a KKK turbo, Audi intercooler, and a 2-1/2" straight through exhaust. I thought long and hard about using a Cummins 4BT, but the Toyo motor was a lot cheaper and easier for me to find (I live right on the Canadian border).
I need a heavier open truck for hauling and towing and I've got a line on a '89 D350 5sp, trying to educate myself before I take the leap!
moT
92smokin blacky
Mar 30, 2010 06:09 PM
archer39
Mar 2, 2010 02:22 PM
PADuallyBoy
May 8, 2009 12:48 AM
bradler
Mar 9, 2009 11:31 AM
jimjawz
Nov 4, 2003 11:49 AM
