Binding in Steering???
Old Mar 7, 2009 | 01:40 PM
bradler's Avatar
Just installed new steering gear, linkage, and ball joints. Went to do the 20 stop-to-stop (engine off, wheels in the air) with the steering wheel as indicated for re-filling power system fluid and noticed that it easily goes to stop when turning right but stops within 1/2in before the stop turning left.
So is there something binding in new linkage maybe? I checked after putting ball joints in and both knuckle pivot stop to stop easy. Or is there a "center of range" on the new steering gear i missed? I thought the recirc ball type it didn't matter and the sterring shaft coupler and pit man arm splines lined up perfect when i put the gear in so i just assembled it like that.
Thanks !!
Old Mar 7, 2009 | 03:25 PM
Swarthy Dago's Avatar
is your steering stabilizer shock hitting the adjuster ? that happened to me.
Old Mar 9, 2009 | 11:31 AM
wadecool's Avatar
The steering gearbox may be too tight. There's a allen screw on top of the gearbox & you need to try loosening it up. Loosen the hex nut & then open up the allen screw a little.
92smokin blacky
Mar 30, 2010 06:09 PM
archer39
Mar 2, 2010 02:22 PM
PADuallyBoy
May 8, 2009 12:48 AM
Stickboy
Oct 18, 2004 12:44 AM
jimjawz
Nov 4, 2003 11:49 AM
