starting problem(maybe)
Old Aug 31, 2004 | 12:25 PM
jiMMyCTD's Avatar
my truck would crank first turn of teh key after the light would go out. (instant start)
recently it will go half a revolution it seems like then fire right up.
just curious if something is going out and or be considered to look into it. i thought maybe the starter itself, but havent looked into anything yet. i drive the truck tons over the last 4 days while moving and it doesnt do it everytime, mainly in the mornings before the engine is warm.
thanks all, jiMMy
Old Aug 31, 2004 | 04:38 PM
How long do you have to crank it before it fires?
Old Aug 31, 2004 | 04:52 PM
jiMMyCTD's Avatar
.5-1 second i guess. before when the light went out i turn the key to start and boom it fired.
not it takes about .5 -1 second and when you turn the key to start it cranks like .5 revolution hence the half to 1 second to start.
basically just asking to see if anything should be checked or if it is a comon starting issue that leads to something else.
**checked all battery terms etc.. everything is tight and secure! **
jiMMy
Old Aug 31, 2004 | 04:53 PM
I wouldn't worry about it.
Old Aug 31, 2004 | 09:47 PM
eng208's Avatar
That is how mine started when the starter was fading. It got progressively worse. It just turns the motor slower and slower. Eventually, after a while, it will fail to turn over. The contacts get burned and the brushes wear out. I wound up getting a lifetime replacement starter at Advance for 136 dollars. That was only about 50 dollars more than I could rebuild my original starter. I felt like it was the way to go.
Chris
Jordan5687
Jun 24, 2007 04:35 PM
Tim9712v
Feb 23, 2007 07:51 AM
cummer01
May 27, 2004 04:07 AM
Cumminsdude
Apr 12, 2004 06:10 PM
