Brake Problem....Maybe? help...
Old Jun 24, 2007 | 02:24 PM
Jordan5687's Avatar
Question Brake Problem....Maybe? help...
Ok, my brakes aren't as responsive as they used to be and not like I'd like them to be. Does the brake lines need to be flushed or something, how much might this cost? Will it help any with being more responsive and stiffer on the pedal? I need to get it done this week possibly, or is there someting else I should be looking at/for this problem? Any help with this will be appreciated. Brake pads are only 2 months old and are in good shape, just checked them.
Old Jun 24, 2007 | 03:12 PM
John Faughn's Avatar
There's not a fluid / lube that should not be changed / flushed , generally I would flush once a yr , every pad change and or at least every 20,000 miles .
There are a lot of issues here , need more info to be able to tell what your problem is .
Some basics , not all yrs. , but a lot of complaints about the dodges brake being weak , could be a cheap set of pads , if now braking at the very beginning of peddle travel , you may need to adjust rear brakes , then there may need some service to the power assist system .
Were the rotors turned when pads were replaced ?
Old Jun 24, 2007 | 03:59 PM
Jordan5687's Avatar
Yeah, rotors were turned. I have them turned every other pad change and that's about every 8 months or so. I do a lot of hauling of about 24-30K# How expensive is it to get fluid flushed and adjusting the rear brakes? The brake pads are the Wagners, Thermo quiet. Supposedly thier pretty good, you'll have to excuse me for the questions, I'm a little new to the diesel world and pretty much automotive. I figured you'd have to change the brake fluid and flush it but wasn't sure when and how often, thanks very much!
Old Jun 24, 2007 | 04:22 PM
gmctd's Avatar
If you have the rotors turned every 8months, possibly the rotors are too thin, which would give slushy brakes and other problems as the caliper pistons extend past the spec limits.
Old Jun 24, 2007 | 04:28 PM
Jordan5687's Avatar
No, I change brakes every 8 months or so, and rotate rotors every other time. So every 16-20 months or so, I rotate rotors. Sorry about the miscommunication.
Old Jun 24, 2007 | 04:35 PM
A good shop should do the adjustment & flush with a pad change .
One of the problems is that if its not done on a regular basis , sometimes the bleeders can be seize / rusted & not be opened , that makes it cost more .
The flushing makes the hole brake system last longer .
I would not suggest skipping this then looking for other issues .
After flushing & checking adjustment and if still light braking , then maybe look into the power assist system .
CODODGE2500MAN
Nov 5, 2009 06:17 PM
Tim9712v
Feb 23, 2007 07:51 AM
jiMMyCTD
Aug 31, 2004 09:47 PM
cummer01
May 27, 2004 04:07 AM
Cumminsdude
Apr 12, 2004 06:10 PM
