sputtering in 5th gear
Old Aug 25, 2010 | 02:16 PM
hot_runner58's Avatar
92 d250, was sputtering and lugging out off and on in all gears, but after some turbo hose replacement and a new gasket, it still only does it once in a while. when it does it, it is when i shift into 5th , and get half throttle or better, lasts into 6th. it starts to spit and sputter, and have no more go power. once it starts to have this problem, it does it all day. but then it might not do it again for a few days, or a few hundred mile, or it might only be 30 miles later. cant find any fuel leaks, havn't found loose connections.
Old Aug 25, 2010 | 02:22 PM
crewcabxlt's Avatar
may be fuel related, or lack of.
Old Aug 25, 2010 | 02:47 PM
getting plenty of fuel in the other gears.runs like a champ. the local dodge dealrship mechanic had no idea. said one of those things have to run it til it breaks.
Old Aug 25, 2010 | 03:27 PM
JonathanFleguel's Avatar
check your air filter and might as well change fuel filter its cheap enough
Old Aug 25, 2010 | 05:57 PM
deanhinsley1963's Avatar
x 2 on fuel filter. then check for sucking air. do you know what the fuel pressure is?
Old Aug 25, 2010 | 06:13 PM
i changed the fuel filter 3 times in last 500 miles. lol. always my first thought. i am narrowing it down to the lift pump i believe. something is starting to squeel when i get on the gas hard, and the injector pump is supposed to have less than 25,000 miles on it.
Old Aug 25, 2010 | 07:03 PM
Sounds like you missed a boost leak.
Old Aug 25, 2010 | 07:36 PM
the boost leak is causing the squeel?
LemonDodge
Sep 7, 2019 03:51 PM
Bsbruce
Nov 6, 2014 09:30 PM
LemonDodge
Sep 16, 2010 07:33 AM
wadecool
Nov 13, 2006 12:37 AM
JM_1
Dec 23, 2003 09:23 AM
