Speed Sensor
Old Nov 12, 2006 | 10:47 PM
broncobilly's Avatar
Speed Sensor
Just out of curiosity, are the speed sensor with wiring still available for our first gens? If so, about how much are they?
Old Nov 12, 2006 | 11:57 PM
flashgordon's Avatar
If your talking about the VSS then yes, still available don't now how much$$ though?
Old Nov 13, 2006 | 06:07 AM
Chrisreyn's Avatar
50$ at NAPA...can get the part # if you need it
on edit I see yours is the 4X..... if it is like my 91 W350 was then you have a two-part sending unit.. the VSS and a gear reducer. both can go out independently.
the 4X VSS was 60$ through the dealer here a year ago and the gear reducer was $90....... the dealer was the only place that could get the gear reducer.
Old Nov 13, 2006 | 06:45 AM
andyt's Avatar
$32 at AutoZone. I bought one last week. They had mine in stock at the store. Hope this helps.
AndyT
Old Nov 13, 2006 | 11:02 AM
dpuckett's Avatar
Speedometer Servive in Colorado Springs makes gear reducers for $50 (might be $60 by now- bought mine in 03). They are the offset type like on 4x4s. Any ratio you need. He deals with a guy who can redo the 90deg ones like in the 4x2s.
What makes you ask about speed sensors?
Daniel
Old Nov 13, 2006 | 09:25 PM
Thanks all for the input! I was referring to the magnetic (speed sensor) which is right about the crank pulley, which has an electrical connection. I just removed it during my recent KDP killing. The wiring on my speed sensor was kinda raggady (PO must have got it tangled with a fan blade??). Isn't the VSS connection on the transmission (auto)?
Old Nov 13, 2006 | 10:36 PM
rlyons's Avatar
Your talking about the crank position sensor?
Old Nov 14, 2006 | 12:45 AM
Rlyons,
That'st it!!!! I don't know why I was calling it a speed sensor? Anyway, are crank position sensor's sill available new?
Old Nov 14, 2006 | 10:49 AM
dpuckett's Avatar
Yes they are.
DP
Old Nov 14, 2006 | 02:07 PM
rlyons's Avatar
Originally Posted by broncobilly
Rlyons,
Well actually we both were right, at Cummins it is called a crankshaft speed sensor.
Old Nov 14, 2006 | 09:26 PM
A least I was in the ball park
supr
18
May 21, 2007 09:29 AM
sjester
May 10, 2007 05:03 PM
tyssniffen
Feb 11, 2006 01:28 PM
Booost Almighty
Jan 1, 2006 01:41 PM
wildmann
Aug 14, 2005 07:15 PM
