Saving a '91.0 W-250
Old Dec 10, 2023 | 06:17 AM
  #271
The old hair spray trick is as follows:
Find an old spray can of Aqua Net or the like. Spray down the inside of the boot and where it attaches to the tubes or intercooler. The hair spray will help hold them together and hold up to a little more boost.
Old Dec 10, 2023 | 07:32 AM
  #272
I got a pressure tester for intercooler systems for another truck I was working on. I bought it from Crazy Carl's. It would have been easy enough to make one, but at $40. I just bought one.
Well I figured I would check some other trucks I have. So I took the air intake off the turbo and clamped it on. I pulled the other boot that goes to the intake horn and plugged that with a plastic re useable water bottle that fit just right and then clamped it on. This isolated the intercooler along with all the boots, tubes and clamps allowing me to pressure them assembled and on the truck.
Remember I have swapped in the 2nd gen intercooler, boots / tubes, clamps, '94-'97 style intake horn and the 2nd gen HX35 turbo on the non intercooled '91.0 motor.
I pressurized it to 10 PSI and it lost pressure pretty quickly. With a little soapy water in a spray bottle I found a clamp that was a little loose and was letting air out the boot. Tightened that up and snugged up the rest off the clamps while I was there. Then I pressurized it up to 20PSI and let it hold for a while. It slowly lost some PSI over a couple minutes...good enough for me.
I bet a lot of you 1st gen inetrcooled guys would find leaky intercoolers with this test. I find most of those are leaking a bit at this point now they are 30 years old.
I plan on testing the rest of my intercooled trucks to see if I catch any other small leaks I was missing.
Cray Carl's ??
A relative of yours ?
Old Apr 11, 2024 | 08:38 AM
  #273
Fired up Poncho for the first time in a month or two last week. I needed it to pull out a truck stuck in the spring mud.
After the week of rain they are calling for, the paved roads should be free of road salt. Which means it is time to start driving the old 1st gens again.
Old Apr 12, 2024 | 04:37 AM
  #274
KRB's Avatar
KRB
All that snow is already gone? Or just gone off the roads.
Old Apr 12, 2024 | 06:48 AM
  #275
After a few days of 50+F rain and warm weather, that 15 inches of snow we just got is now 100% gone - other than the piles where the roofs dumped snow.
We are in the middle of 5-6 days of warm rain, which should be enough to wash off the blacktop. Once the sun comes out and dries the road up it should be good.
Old Apr 16, 2024 | 05:33 PM
  #276
Took Poncho out to lunch at the local taco truck with my daughter. We had lunch sitting on the tailgate.
Good times.
Old May 8, 2024 | 05:58 AM
  #277
Poncho is all loaded up with some metal for a trip down to the scrap yard today.
I have a collection of a few roughly 30 year old brass radiators that are spanked and several leaking aluminum intercoolers to trade in for some $.
Old May 9, 2024 | 08:45 AM
  #278
They are paying decent cash for old brass rads. I got almost $60 a piece for some rotten, old 2nd gen radiators.
Oh, and the truck drove, great. Nice being back in the old 1st gen.
After the scrap yard, I got to meet up with my daughter and grab some spicy Thai food for lunch. There is a little hole in the wall style kitchen that only serves lunch and is almost completely take out orders. Their $11 lunch options are always worth it.
Old May 10, 2024 | 09:22 AM
  #279
Oooh, sounds so yummy.
Do they fry the cat, or bake it before serving it to you ?
Meow !
Old May 11, 2024 | 06:13 AM
  #280
KRB's Avatar
KRB
We have a similar joint here. It stays packed. They even make a bunch of extra meals and donate to local shelters. They rate their hotness by "stars", I find 4 provides about the right bite and flavor for me.
Old Nov 11, 2024 | 09:15 AM
  #281
Charlotte drove Poncho around yesterday with me. We did a little Christmas shopping and I took her out to lunch at a different Thai place.
One of her first comments after driving the truck for 20 minutes….”Everybody seems to wave at you when your driving this.”
Why yes they do, I replied.
Old Jan 26, 2025 | 05:23 PM
  #282
The lift was free, so I put Poncho up in the air to do a solid pre-season check up. Everything was greased up, even the grease-able shackle bolts. Which I used when I did the mild front lift springs, rear shackle flip and bracket drop on the suspension. I did the rear shackle flip and drop bracket to loose the factory lift block years ago.
All the driveshaft joints took grease.
The Dana 60F axle has a set of recently swapped in non grease-able Spicer U-joints in it. The front end has been gone through completely over the years, so everything was good to go.
The rear axle had signs that the pinion leaked, so I blew out the breather hose and vent. The 'Rag, NP-205 and axles where checked for fluid levels.
When it all looked up to snuff under the rig, I sprayed it down with 2 cans of Fluid Film. I got it in the cab mounts, rockers, along with on the brake lines and the frame - paying extra attention to behind the fuel tank. I also got the rear axle shock / U-bolt saddles. All the places I have seen WAY too many Dodges rot out in.
Tomorrow I can get it off the lift. Then other than a few minor interior things I may or may not get to, it should be ready for another summer.
Old Jan 28, 2025 | 05:24 AM
  #283
KRB's Avatar
KRB
Ahhh, summer. Seems so far away right now. But soon I'll be complaining about mowing the yard and weedeating...
Were you able to detect any difference in handling after losing the blocks and flipping shackles?
Old Jan 29, 2025 | 07:29 AM
  #284
The suspension mods made the truck much more enjoyable to drive in unloaded, yet still handle the loads it normally sees. Things like my #800 ATV, firewood, Dana 60/70 axles, #1200 Cummins motors, camping gear.
It used to bounce around like an Amish hay wagon with the factory leaves / block, camper springs and aftermarket airbags.
I have a bunch of pictures of the suspension mods in post #147 and 148 of the thread.
Old Feb 2, 2025 | 05:42 AM
  #285
KRB's Avatar
KRB
How big is your shop anyway? Seems like you have lots of projects and parts storage etc.
