return line?
Old Sep 9, 2009 | 09:31 PM
DU.DP.'s Avatar
return line?
i'm having some trouble in the mornings when i start my truck, nothing major at all. its just if i go to step on it a little i get a small sputter like there is air in the system. i started with the fuel filter but it still acts up overnight. anyways im just taking things easy for now and starting small.
my question is does anyone have a pic or diagram of the return line and know where i can get one cheap?
Thanks for all the help as always i appreciate it!
Old Sep 10, 2009 | 08:32 AM
94ram's Avatar
you should wait for the oil to warm up rather than stomping on right away hahaha
Old Sep 10, 2009 | 08:42 AM
apwatson50's Avatar
The stock fuel lines on the 91.5+ are pretty solid, I doubt that is your issue. If anything it is the o-ring on the fuel heater, or the heater is loose.
Old Sep 10, 2009 | 04:08 PM
DU.DP.'s Avatar
ok so they're solid on this truck. i was just going based off my ford i had to replace each individual line now that i know this where is a diagram of this or is it easy to spot?
Old Sep 10, 2009 | 04:50 PM
apwatson50's Avatar
The stud that the fuel filter screws onto, also holds the fuel heater to the head. Unscrew that stud and the heater will come off, and you can replace the seal. Just be careful as sometimes the heater will try turning with the stud and you can break the electrical plug.
Rick 12v CTD
Sep 23, 2011 05:21 PM
Scotts_D250
Jul 10, 2011 01:05 AM
ctd4stan
May 18, 2009 02:56 PM
Tiara3100
Jan 14, 2008 10:06 AM
hellotbone
Feb 26, 2003 03:28 PM
