2 WD front lift
Old Sep 10, 2009 | 03:12 PM
1st gen wontabe's Avatar
2 WD front lift
I saw on e-bay a set of coil spring spacers for the 2 WD.I've seen discusion on this site about this ,but can't find it now.would someone with more computer skills than I get this item to show up below so I can get some opinions.e-bay search item # 120467764493. If I get new springs to get my ride hieght back how long before the new springs settle?Since my old springs are already settled I figured I could raise it now and it'll stay there.Thanks,Bobby
Old Sep 10, 2009 | 05:43 PM
AUGIE DOG's Avatar
You might want to think about replacing the coils. If you want to raise the front end I know some of the fellas on here have used the severe duty coils to achieve this. Also you need to check the rubber spacer cup that sits on top of the spring. These will cause sag in the front end. Check in the sticky for coil and front suspension part #s. Hope that helps. I know others will respond to your post. Good Luck!
Txwelder
Nov 26, 2025 01:53 AM
doomgaze
Apr 13, 2006 01:21 PM
0425004x4
16
Jan 23, 2006 06:43 PM
Txwelder
May 19, 2005 06:10 PM
lucey
Apr 21, 2005 09:53 PM
