remote vss
Old May 12, 2009 | 03:28 PM
JWood's Avatar
remote vss
is it possible to drive the VSS through a cable on my 93 auto...?
this sounds wierd, but mine keeps failing. I thought id try to put it in a friendlier location.
any thoughts?
thanks, Justin
Old May 12, 2009 | 03:29 PM
Sure, no reason you couldn't if you can find an extension type speedo cable.
Old May 12, 2009 | 03:35 PM
JWood's Avatar
thanks... do you know of any reason these would fail quickly? Ive gone through 3 in a year...
I replaced the pigtail wiring and heatshrinked everything really nice, still fails...
where might I find that cable???
Old May 12, 2009 | 03:39 PM
2 wire or 3 wire VSS?
A speedo shop should be able to scare something up.
Old May 12, 2009 | 04:01 PM
JWood's Avatar
its a two wire...
I found an extension cable at PATC,
I am concerned that I keep going through these, how often do you guys have a failure here?
Old May 12, 2009 | 06:30 PM
I don't know why you are having bad luck with them. Have you tested the old ones with a drill to see if they make voltage?
Undertaker
Oct 26, 2009 03:02 PM
mrwaters
Mar 14, 2006 11:31 AM
auber
Dec 5, 2005 01:36 PM
JMZ
Apr 5, 2005 06:41 PM
Super4x4Duty
Oct 29, 2004 07:46 AM
