Relay for gauge lights
Old Sep 6, 2009 | 11:03 AM
Mike T.'s Avatar
Anyone using relays for your gauge lights? If you are what amp did you go with? By adding additional gauges I was just wondering if it's necessary.
Old Sep 6, 2009 | 11:24 AM
93flatbed's Avatar
I wouldn't think you would need it, I can't see all of the bulbs drawing enough amps, but that's just me.
Old Sep 6, 2009 | 11:34 AM
Mike T.'s Avatar
Just a bit concerned about the light switch.
Thanks
Old Sep 6, 2009 | 11:37 AM
If you put them on a relay you couldn't dim them.
Old Sep 6, 2009 | 11:50 AM
Kansascrewcab76's Avatar
you could dim them if you wired in a rheostat after the relay
Old Sep 6, 2009 | 11:53 AM
Mike T.'s Avatar
Thanks guys
Old Sep 7, 2009 | 03:15 PM
92roughstock's Avatar
I think the extra lights on the dually do most of them in. That, and trailer lights. I woudnt worry about 2 or 3 gauge lights.
Old Sep 7, 2009 | 03:54 PM
HappyCamper's Avatar
The bigger bang for headlight switch relief is to relay the headlights. If you tow, also relay the trailer lights - then adding a few gauge lights is not going to matter to the switch and you retain the dimming function.
Old Sep 7, 2009 | 04:33 PM
SOOT4BRAINS's Avatar
Pod Boy (on hiatus)
Then headlights are what usually melts stuff, but putting in LED lights in the gauges will help as well. They are brighter, but they also draw less power than a standard bulb. You get brighter lights that are still able to be dimmed and take some strain off the switch.
Old Sep 7, 2009 | 06:37 PM
Boatnik's Avatar
If you relay the head lights it takes a lot of load off the switch and you can upgrade the wire to the head lights so they work better than stock. The voltage drop on the factory harness to the head lights is signifcant due to the small wire cross section.
Old Sep 7, 2009 | 07:31 PM
archer39's Avatar
i have my lights wired to a power distribution block similar to this. The distribution block then has a 40amp relay that switched to come on with the key. It is also the source for my plow controller, brake controller any anything else i want to add in the future.
Old Sep 8, 2009 | 01:44 PM
apwatson50's Avatar
Both my trucks have the headlights relayed. But on the 2wd I went one step further and tapped into the tail light circuit and put the tail/running lights on a relay. The one I tapped into is only for the rear tail lights, the front running lights aren't on that tap. But this carries the load for any trailers attached also, that was my main concern.
Also all the gauge lights I put LED's in so the added load from them is very very minimal!
Old Sep 8, 2009 | 06:39 PM
Mike T.'s Avatar
Thanks for the suggestions guys. I've relayed my running lights for my cabover and boat trailer and I guess I'll do the head lights next. Dumb question, can the bulbs be replaced in older gauges with new led type? I'm not all that familiar w/leds.
Chrisreyn
Nov 6, 2007 08:03 AM
Hercules130
May 31, 2006 08:58 AM
supr
Feb 23, 2005 02:51 PM
mazeppa
Feb 10, 2004 06:54 PM
