Rebuild it or replace it ?????
I think my power steering gear box has gone the way of the DOE-DOE BIRD, i'v not rebuilt one of these(can't learn any younger), anyone, has i could use some advise new remanf., 160.00@ O'RLY kit 50.00---what ya'll think???
I bought a rebuild kit for fifteen dollers. There are a lot of pieces parts but the instrutions are pretty good. I got it to replace the seal and bearing around the input shaft. Money is always tight these days and it is major factor. I went thru two rebuilt boxes before I got this one and still had to do repairs on it. IF there is a next time, I am willing to buy a new box and not get somebody elses problems.
Whichever you decide keep us posted. My power steering works a bit upon startup but is barely detectable when twisting around later on. Of course I do appreciate the upper body and arm development that's resulted from "armstrong steering" but I druther do that pulling on wrenches.
So far sooo good. My unit didn't leak after i put in new in-put seal. replaced the coupler unit too. It just had to much play then it would kind of hang when turned to the right. I found this on inter.net. dodgeram.org/tech/repair/index.html Followed instructions,,but i didn't take gear box off my truck, just took power hoses off , jacked front wheels off the ground set pre-load by the inst., took steering wheel cover off , put tork-wrench on steering nut to set pre-load. The PO had the allen screw run down to far , which made steering to tight, i screwed it up all the way , then loose& tighten until all the play was gone,then loosened it off a little at a time till it felt like my d350, so far sooo good.I hope its right ,saved 150.00-200.00 bucks& i learned something about our trucks.
sherpadad
Aug 17, 2007 02:29 PM
bigmack2500
Dec 17, 2006 06:01 PM
hw101
Apr 13, 2003 08:53 PM
