Rear Sway Bar
Rear Sway Bar
I was thinking of installing a rear sway bar.
Other than new, what years etc. would I look for to find one in the junk yard?
Thanks
Thanks
If you want one that will bolt up without any fabrication, you will have to buy aftermarket. Otherwise you'll just have to look around and find one off a newer truck that you think you can make work.
Aaron
Aaron
I had just ordered one from summit, and it wont fit. Its supposed to go over the driveshaft, kinda in front/on top of the rear end, but I have this dang fuel tank thing........... Its from addco, there are a couple of models, but obviously I don't know which one works.
I bought a hellwig sway bar i'ts 1 1/8 dia.. and it fit.
http://www.suspensionconnection.com/...FQgRFQod1UzLDg
Mike
Mike
Mike
Mike
Mike
try jcwhitney, also. They carry the Hellwig line. I installed mine(2 hours) and it made a difference in the handling. Like it advertizes.
No drilling...all bolt on. I have installed another Hellwig sway bar on my 2002 powerstroke, and looked at tons of others, and typically sway bars make a moderated to extensive "loop" over the top of the rear diff. The Hellwig sway bar from JCW has the loop turned underneath and close to the front, underside of the diff, just under the drive line. I thought it was a mistake at 1st, but directions show exactly that. 1 1/8" solid tubing (powdercoated)w/ all fasteners and hardware for $189.00 if I recall corectly.
tcr
12-04-2007 12:15 PM
Robert373
04-03-2007 12:20 PM
Explorer
06-06-2003 12:24 AM
