Which rear axle is on 1992 3500 4WD?
Old May 27, 2007 | 09:25 PM
dieselpuller's Avatar
Smile Which rear axle is on 1992 3500 4WD?
I just purchased a 1992 3/4 ton 4wd automatic which I am going to pull in work stock this summer. I am having a pulling valve body and pulling torque converter installed and want to have a Dana 80 instead of the 70 it has now. I found a 1992 1 ton 4wd for sale one state over and was wondering if the rear axle is a Dana 80 and if there might be anything else on the 1 ton I might benefit from on my 3/4 ton. Thanks in advance for your help gentlemen!
Old May 27, 2007 | 09:44 PM
torquefan's Avatar
Nope, all the 1st gen diesels had Dana 70s in the rear. 2nd gen 2500s with manual transmissions had Dana 80s as did all 3500s.
Old May 27, 2007 | 09:53 PM
Other than the dual rear wheels (maybe) and 3" brake shoes it is the same truck.
Old May 27, 2007 | 10:24 PM
Thanks very much. Would the 1994-2002 3/4 manual gas trucks also have the dana 80 and will all 3500's have the dana 80?
Old May 27, 2007 | 10:37 PM
They started with the 80 in '96 I think. There is no need to upgrade to the 80 unless you break the 70, lots of guys pull heavy loads with the 70 with no problems.
Old May 28, 2007 | 10:55 PM
torquefan's Avatar
If I remember right, only the manual equipped V10 2500 trucks had the 80. I think all the 3500s did too, even the few V8 equipped trucks.
codiesel
Nov 26, 2014 09:25 PM
codiesel
May 13, 2014 12:30 PM
roxxx
ABDTR #5
Sep 27, 2009 05:13 PM
65fury
Apr 4, 2009 02:40 PM
