Radiator upgrade options
Old Jul 30, 2012 | 09:56 PM
mopar2ya's Avatar
What are some options to upgrade the radiator on a 93 IC truck? Pulling the GN trailer it gets to 210 without even pushing it.
The radiator has been rodded out, new fan clutch... Just gets too hot pulling....
Old Jul 30, 2012 | 10:45 PM
jimbo486's Avatar
How often are you having the coolant flushed and replaced along with hoses, water pump and thermostat?
Old Jul 31, 2012 | 08:47 AM
mopar2ya's Avatar
All the work I had done was 2 months ago. I was about 107 outside temp and I was pulling the trailer and keeping boost at 15 psi, the EGTs were fine, but the water temp was getting up. When I exited at a off ramp it cooled off pretty quick. I just dont think there is enough capacity... BTW I even added some water wetter to squeak all I can out of the cooling system.... BTW I was using the A/C which doesnt help...
Old Jul 31, 2012 | 11:06 AM
Old radiators often have the fins separate from the tubes, they will look OK at a glance but you can just pull the whole strip of fins out.
One of those nice aluminum Griffin radiators would probably fix it.
Sent from my Paranoid Android HD2 using Tapatalk 2.
Old Jul 31, 2012 | 12:06 PM
jstone44720's Avatar
Check out Built Tough Radiators. They make some serious aluminum 3 and 4 core rads.
Old Jul 31, 2012 | 12:12 PM
j_martin's Avatar
If yer pulling 15 psi boost steady at 107° ambient, with the AC running, and the water temp stays under about 230° and you don't lose any coolant, I would say you are running just fine.
107 is hot
AC at that ambient temp would be running 250 or so, in front of the radiator.
15 psi boost is making some power, and a lot of heat.
It's normal for the gauge to run up under such circumstances. It is only a problem if you lose coolant.
Old Jul 31, 2012 | 01:06 PM
rebal's Avatar
if your truck is an automatic its just about a lost cause trying to cool them with the stock radiator and a tuned motor, the auto, dumps tons of heat into the heat exchanger heating up the water too. I did see a first gen that had the core support modded real heavy and had a 2nd gen rad, and intercooler he was tired of heat but it looked like a lot of work.
Old Jul 31, 2012 | 03:54 PM
mopar2ya's Avatar
Its a 5 speed. I just wonder if a larger aluminum radiator would give me additional cooling.
I agree with you Jmartin which is why Im looking for more capacity. The newer trucks even in 94 had a much larger radiator. I know im asking more of the truck than it was designed for, just need to add more for the added capacity I guess...
Old Jul 31, 2012 | 05:33 PM
TRENDZ's Avatar
Do you have a fan shroud installed?
Old Jul 31, 2012 | 06:50 PM
The_Head's Avatar
Griffin can make one for you. There was a 2nd gen article called the "ultimate towing rig" and it ran a Griffin radiator. They even have a part number for our trucks if you search their site.
Old Jul 31, 2012 | 09:55 PM
mopar2ya's Avatar
Yes on the fan shroud...
Old Jul 31, 2012 | 11:44 PM
The_Head's Avatar
Your sig says 1,186,000 miles. Is that a typo?
Old Aug 1, 2012 | 10:34 AM
user name's Avatar
Has anyone run the Griffin radiator in a first gen?
Old Aug 1, 2012 | 11:35 AM
DodgeFreak's Avatar
nope he has a thread or a post about the million miles.....not sure where though.
8liter
Sep 22, 2012 10:19 AM
afromla
Jan 19, 2010 04:39 PM
2nGlenn
Oct 29, 2007 10:34 AM
Redleg
Oct 14, 2005 07:45 PM
mopar2ya
Jul 10, 2005 12:28 AM
